Question about Sony KDS55A2000 55" HDTV
Can't find reset after replaceing lamp
I can'tfind my manual
Message on screen says lamp needs to be replaced then timer reset. Need lamp and instructions to reset timer
The lamp time reset will be or should be in the owner manual---Google the model number with keywords "lamp install" with the model number and the "manual" with the model number---Google can be a great help.
Nov 01, 2012 | JVC Lamp W/ Housing For Hd-52g786 /...
Replaced XD300U projector lamp. Need to know how to reset lamp timer. Won,t turn on because lamp timer has expired to 0. Needs to be reset. Lost our manual. Please help.
"Reset the lamp counter
i. Press and hold Exit on the projector
for 3 seconds to display the total used
lamp time.
ii. Press Menu on the projector or on
the remote control to access the lamp
hour timer. An adjustment message
will appear.
iii. Press or to reset lamp hours
and press EXIT to leave."
Apr 21, 2008 | Televison & Video
How to reset lamp timer
The operator's manual has no reference to a lamp timer. The only user setting associated with the lamp is "Energy" for setting the lamp power to Standard or Bright. I'm surprised; most LCD RPTV sets have a timer that should be reset after replacing the lamp, and the instructions for doing so are given in the manual. The manual for this model only says to replace the lamp if the picture is getting dimmer (page 77).
Sep 24, 2012 | Mitsubishi WD-60737 TV
Janome sewing machine manual
go to the websites of
sewvacdoctor.com
or
a1sewingmachines.com
and email them about a manual, I've look several places & can't
find one,, so try them
Sep 14, 2012 | Sewing Machines
Our projector indicates that the light bulb needs to be replaced after replacing the light bulb once it still indicates that it needs to be replaced.
This is the excerpt from the manual on how to reset the lamp life timer.
Turn on the projector and use "Lamp Reset" after the lamp module is replaced.
Lamp Reset: (i) Press "Menu" ?§ (ii) Select "Options" ?§ (iii) Select "Lamp settings" ?§ (iv) Select "Lamp Reset ?§ (v) Select "Yes".
Jan 12, 2011 | Optoma HD65 DLP Projector
How to reset lamp timer on pt 50L C-13
Their manual says:
After lamp replacement, you must reset the lamp
time. Refer to the instructions enclosed with the
lamp unit (Part No.: TY-LA2005).
lamp unit (Part No.: TY-LA2005)."
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC13
Aug 09, 2010 | Panasonic PT-50LC13 50" Rear Projection...
AFTER REPLACING LAMP THE LAMP LIGHT IS STILL FLASHING
Look in the manual under "resetting the lamp timer"
This must be done with most any replacement
Browse to:
http://www.retrevo.com/r/391dj496/48/Lamp+Timer+Reset#q=JVC+HD-61G787
On that page is the (lower) is the exact procedure on resetting the lamp timer. You can also down the entire manual in PDF format.
Cheers
Jan 15, 2010 | JVC HD-61G787 61" Television
Lost the manual - I am replacing the bulb
remove the lamp door, remove the lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
Oct 08, 2009 | Sanyo PLC XU35 Multimedia Projector
Projection lamp nearing end of life replace lamp still coming on
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
Dan
Mar 09, 2009 | Sony KDF46E2000 46" Projection HDTV
Replaced bad lamp on t.v. and was told there is a reset button
the reset lamp time in in your users manual, and or should come with the new lamp..
Jan 09, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Sony KDS55A2000 55" HDTV Logo
299 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
