Broad dark line on right edge of copied papers
There is a rather broad dark edge on the copied pages along the right edge of the page. We ahve cleaned the glass and the cartridge is printing otherwise OK. Also occurs with the printing function.
  • 64 Answers
If you have the black line on copies and scans but printing from P.C is fine, then your scanner is broken.
Contact your printer manufacturer for a replacement or repair.
Posted on May 13, 2010
I have an hp2430, it is pringinting shadows along the left edge of the papers and a line along the right side. I have printed a cleaning page 3 times and replaced the cartridge, running the cleaning page...
the line could be caused by a scratched DRUM unit or a contaminated trasfer roller... And the shadow is probably a broken MICA ROLLER in the FUSER,
To get rid of the line (if the drum is OK) you need a mantenance KIT for that model, (pickup roller, transfer roller, separating pads etc...), for the shadow you need a new FUSER
Cheers!
Mar 22, 2011 | HP LaserJet 2420 Printer
Toner on paper edges
The cleaning blade inside of the drum unit is worn out. Replace the Drum Unit
May 19, 2010 | Brother IntelliFAX 4100 Laser Fax
Copying very dark lines down page.
hi just clean complet scanner mirrors and charge and transfer crona wires if solved ok if not solve just replace the drumcleaning blade.
thanks
May 14, 2010 | Toshiba 1370 Black and White Copier
I get lines and can't read the right side of copies that I make with the 1270e. How do I fix this?
You have not specified why you can't read the right side of copies and I am assuming that the reason is because the 'lines' are covering the text. I can offer a solution to the lines issue.
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Sep 23, 2009 | Office Equipment & Supplies
Black line along the right side near the center when copying ONLY
first, the line are in all printing pages, or only when you make copies?,
if the line are in all printing pages, maybe your fuser has damage the fuser film sleeve,(aprox, 10-20 dlls), if only this line are when you make copies, maybe the glass in the scanner are dirty(clean and try).
i expect this solution your problem
Aug 05, 2009 | HP LaserJet 3050 All-In-One Printer
Dark edge printing on paper
Hi!
Here is a link to the manual to Samsung ML1740 laser printer (the "Troubleshooting" part)
Hope it will help!
https://manualsbrain.com/en/manuals/1437656/?page=95
Jan 04, 2018 | Samsung ML1740 Laser Printer
Xerox phaser 7700 having problems printing transparencies and accumulator belt problems
Hi xander4265:
I
Streaks in direction of paper travel
There are dark lines running along
the page in the direction of paper
travel from the leading edge to the
trailing edge (B-size print shown).
The printer displays no error code.
Note A-size prints are processed
through the printer with the short
edge of the print parallel to the
direction of the paper path --
making horizontal print artifacts
parallel to the shot edge of the
print.
B-size prints are processed
through the printer with the long
paper path -- making horizontal
artifacts parallel to the long axis
of the print.
1. Check the end of life for each of
the consumables by printing the
supplies usage page. From the front panel’s Printable Pages Menu, select
Print Supplies Page.
2. Run the solid fill test pages; From the front panel’s Printable Pages Menu,
select Service Pages, then select Print Solid Fill Pages. If the missing bands
only occur in a single primary color, replace the print cartridge of the affected
color.
3. Swap print cartridges and run another test print.
Note Under some circumstances, streaking may occur in the margin of
SRA3-size paper. This is due to the edges of the paper extending
beyond the end of the imaging components. print-quality in the
margins of SRA3 paper is not guaranteed.
4. Inspect the Accumulator Belt cleaner; replace the cleaner, if necessary.
5. Run the Remove Print Smears routine. From the front panel’s Support Menu,
select Improve Print-Quality?, then select Remove Print Smears.
6. Replace the Developer Housing Assembly (RRP 27, on page 7-171).
7. Remove the print cartridge and (with a flashlight) check for debris along the
edge of the developer housing.
3041-42
Leading Edge
hope that this will help you.
Sep 18, 2008 | Xerox Phaser 7700 Laser Printer
Mark on page
First try to clean the head: Open the top cover and print head, Moisen a small piece of soft, lint-free cloth with alchol and keep wiping the edge of the print head... second, This could also be caused by excess lubricant on the tonercartridge . Print or feed up to 10 sheets of paper through the printer to eliminate the marks. If the problem continues please contact Brother Customer Service at 1-800-284-4329 Monday through Friday, 9:00am - 7:00pm EST, excluding holidays.
Nov 29, 2005 | Brother MFC 1950MC Printer
225 people viewed this question
k24674
jasbo
jasbo
