Question about Sony FD Trinitron WEGA KV-32HS500 32" TV
Cable box indentifyer on screen stays on - Sony FD Trinitron WEGA KV-32HS500 32" TV
  • 10,594 Answers
Press Display or Info button on tv remote, on-screen display will disappear.
Thanks.
Posted on May 12, 2010
My TV will not connect to the cable box unless I unplug it and plug it back in!!
Hey Cc.
I have the same problem sometimes... I got a new power cable and new box from the cable co., it has worked well so far..(over a year!)
Sep 15, 2017 | Televison & Video
Samsung screen goes grey with green letter? Have Comcast cable
When the green letters appear, turn off the cable box only.
If the screen changes, the problem is in the cable box or hookup.
If the letters stay, there is a problem in your TV.
Jan 09, 2015 | Samsung 6030 Series UN55FH6030 55" LED TV...
I have a 42 inch led tv bought T Xmas
It usually matches the signal being sent to it. the movie etc. is 4:3
If you have a hi def cable/fios etc box you need the HDMI cable or the 5 AV cables to actually watch it in HD then this should stay at 16: other wise your stretching the picture makes people look funny
Hope this helps, God Bless :O)
Apr 24, 2014 | Toshiba Ct90325 Remote Control
Green light stays on when trying to turn off tv. picture go's off when cable remote is used but green light stays onand you can see that screen is still on?
You need to set up the cable box remote for your TV , now you are just turning off the cable box. Some cable boxes have a switched plug on the back that will turn on and off with the box. If yours has the switched receptacle you can use that to turn the TV on and off by plugging your TV into the switched receptacle. Make sure the TV power is on, the receptacle will kill the power so the clock on the TV wont work. Otherwise you need to set the code for your TVs remote and use the system power button.
Apr 23, 2014 | Mitsubishi LT-46153 LCD TV
Screen stays blue and wont show the picture
TV may be on the wrong input and that will give you a blue screen. When you turn the TV on and the screen starts lighting up it should show on the screen what input the tv is on. If it is not on correct input change input with the TV remote or buttons on the tv. If it is on the correct input try a power cycle on the cable box, just unplug the cable box power cord for a few seconds and then plug it back in. If neither of these solve the problem describe how the cable box is connected to the tv.
Mar 16, 2014 | Mitsubishi WS-55513 55" Rear Projection...
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
Aug 05, 2012 | Dynex DX-LCD32-09 LCD TV
When I hook up the cable to the RCA truflat tv the screen stays blue. I had it working with a cable box, do you know why it's not working with just the cable?
Your cable system is probably digital, and the tuner in this TV isn't compatible with the system. The cable box output was a regular TV channel 3 or 4 signal the TV could tune in. Without the box, though, your TV's tuner sees nothing. You'll need to stick with the box.
Jan 12, 2011 | RCA TruFlat 27F520T 27" TV
When I turn on the monitor the green power light flashes,however, the screen stays black. If I disconnect the cable from the computer the monitor shows a box on the screen that says no signal. If I...
It could be a bad cable, a bad connector on the screen itself, a major problem with the screen and something as simple as the driver or settings on your graphics card.
If you are trying to use the screen as a secondary screen you need to enable it on the Operative System. Try different cables and different cables for the other connector types available on your screen and graphics card. Try another screen with your current setup too, and if possible try your screen with other PC. These tests will show you what kind of problem you are experiencing and will provide you the solution too.
Jan 27, 2018 | Samsung Syncmaster 192N 19" LCD Monitor
A black box keeps appearing in the middle of the screen and stays on until I either turn off the TV or turn on the settings screen and clear it
Somehow, the cable box or some other device changed the settings for the caption box on the TV. While no closed captions were appearing on the screen, the box was being displayed. The box stopped popping up when the captions setting was turned off.
Dec 27, 2009 | Toshiba 27AX61 TV
Little transparent box with 2 in top right hand corner of screen
I found a suggested solution, reboot the cable box (unplugging & replugging) and the mysterious #2 box should disappear.
Jan 03, 2009 | LG 47LG50 47 in. LCD HDTV
Sony FD Trinitron WEGA KV-32HS500 32" TV Logo
70 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
