FixYa.com
Tags:
Umax Astra 2100U Flatbed Scanner
Power adapter for Astra 2100U (by 2 users)
posted by LunachikFrnj on Mar 29, 2008
I'm unable to locate the power cable that came with the scanner. If a universal adapter can be used, what voltage, etc. should I use?
Comment by LunachikFrnj, posted on Mar 29, 2008
Thanks for your help! Sounds like I should stick to commandeering my friend's scanner & dropping the files on a disc, huh? Well.... it was worth a shot! :o)
Thanks again for your time & brain-power!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on May 04, 2008
I have the Astra 2100U scanner. No power supply, no power markings
on the scanner, orcanner, please reply the volts and polarity. Thank you.
Best Solution
FixYa! (100)
TampaNative
Rank:Wiz Wiz
Rating: 83%, 152 votes
The Voltage and Current/Amperage draw should be printed on a tag on the scanner itself. The scanner isn't worth replacing the power supply in my opinion as you could probably replace the scanner for a little more than what a power supply will cost.
Comment by TampaNative, posted on Mar 31, 2008
You're welcome, and do put the files on Disk and use your Friends scanner, I would. :D
Rating Locked! (?) LunachikFrnj has rated this solution as FixYa!
Can you Help with these Scanners problems?
Scanners
Live local police scanner on...
recently while browsing the... Answer This...
Scanners
Driver For Umax Astra 5650
Do u have Driver Umax Astra... Answer This...
astra umax 2100u scanner
Hi, I have a problem with my... Answer This...
Astrsa 2100U scanner with UMAX...
I'm trying to set up scanner on... Answer This...
Lamp does not go to full...
I suspect the lamp is... Answer This...
Repair Service
Find Scanner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
