Question about Ricoh 6513 Copier
Patchy Prints I'm getting patches of missing toner on my prints. It's worse on the first than the second copy. It only happens on normal paper setting, If I put the same paper through as thick or actually use thick paper it is fine.
  • 14 Answers
I believe that the Heat roller in the Fuser has a build up of toner on it(in some areas) and as a result is not fully fusing the toner into the paper. when you use a thick setting you are actually slowing the speed down to allow more heat to the toner. the thicker paper causes more pressure allowing the toner to fuse properly. I would say you need a new Heat roller and possibley a pressure roller. You could try running 20 copies of a blank white page. Sometimes this will help. Poor fusing can also cause a previous image to come up on the next page or repeat itself down the page. A service call is in order if this does not work.
Hope this helps
Dave T
Posted on Jun 15, 2008
6ya staff
SOURCE:
Printed images are grainy? especially the skins. any solution
This could be caused by a couple of things. The first one is the toner cartridge. A defective or low toner cartridge can cause light "grainy" looking copies. If you have a spare toner cartridge try that first. The second possibility is dirty scanner optics. The scanner bar that lights up under the glass and moves back and forth has 3 mirrors on it. When they get dirty is causes your scanned image (before it gets copied) to appear light and patchy looking. The glass must be removed by removing the 4 screws on the left hand side. Then the scanner can be pulled out and the 3 mirrors cleaned. If you have the machine hooked up to a computer to be able to print then these mirrors will NOT affect PC prints. If PC prints are grainy then that would point to the toner. The dirty mirrors will only effect the copies.
Good Luck and Thank You for using Fixya.
We are having a contest this month that is based on positive testimonials. If my solution is helpful please leave a short testimonial for me.
Thanks!
Oct 06, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
My Brother HL1230 printer prints with whole lines of text missing several times on a page and gets worse by missing more lines if printing several pages. It has a new toner cartridge. How can I sort this...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 28, 2010 | Brother HL 1230 Laser Printer
Kyocera mita km-1820 not printing clear copies
you have to check the duplex unit on the machine itself.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
May 01, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
Missing the manual - how to collate??
By using the Duplex button on your machine, you can set the machine to
print copies on both sides of paper.
1 Press Duplex.
2 Load originals face up in the ADF.
3 Press the Scroll buttons until the binding option you want appears.
Off: Prints in Normal mode.
1->2Side Short: Prints pages to be read by flipping like a note
pad.
1->2Side Long: Prints pages to be read like a book.
2->1Side: Scans both sides of the original and prints each of them
on separate two papers. (SCX-6322DN only)
2->2Side: Scans both sides of the original and prints them on both
sides of a paper, this function produce exactly the same print out
from the original. (SCX-6322DN only)
2->1Side Rotate2: Scans both sides of the original and prints one
of them on separate two papers, but the information on back side
of the original is printed 180° rotated. (SCX-6322DN only)
4 Press OK to save your selection.
If the mode is enabled, the Duplex button is backlit.
Collation
You can set the machine to sort the copy job. For
example, if you make 2 copies of a 3 page original,
one complete 3 page document will print followed by a
second complete document.
1 Press Copy.
2 Load originals face up into the ADF.
For details about loading an original, see
page 5.1.
3 Enter the number of copies using the number
keypad.
4 Press Menu until Copy Feature appears on the
bottom line of the display and press OK.
5 Press OK when Copy Collation appears.
6 Press the Scroll buttons to select Yes.
7 Press OK or Start to begin copying.
One complete document will print
http://www.websitetoolbox.com/mb/copierquestions
Jan 23, 2009 | Samsung SCX-6322DN All-In-One Laser...
HP CP1215 prints a line of black dots down the centre of page. Happens with all settings on high quality paper. Same with normal paper.
Perform a half paper path test. Put the paper in the manual feed tray, print a test page, when half of paper is pulled in the printer open toner door so the printer stops. remove the toner and check print is the issue there you have trouble with your toner cartridge. Otherwise there is an issue with fuser. Mostly I think you have an issue with tonercartridge, try take it out and shake gentle
Nov 05, 2008 | HP Office Equipment & Supplies
Samsung CLP-510 Print Quality problem
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
I've also seen this sort of thing caused by a crusty build-up of toner on a wiiper blade on the Transfer Belt, and or Drum.
Dec 01, 2007 | Samsung CLP-510 Laser Printer
Large grey streak down center of page
It is the fuser at rear giving you grief! The upper heat roller has a teflon coating that wears away allowing toner to stick to roller and smudgin prints as they pass threw it. The fix is to replace fuser assembly, take to brother dealer to fix.
You can prove it to yourself by timing the print to stop mid way threw machine then remove print cartridge and look at paper, you should see a image is good untill it hits the fuser,( pre fused image "rubs off" paper.) If you have changed drum and toner thats all it can be. They all do it in time.
Fuser is hot bit at rear, pull out drum and look in the back with a small torch you will see upper heat roller is worn, guestimation $90 for fuser plus labour to fit.
Nov 16, 2007 | Brother IntelliFax-2820 Laser Fax
Ricoh 6513 Copier Logo
132 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
