Question about Speed Queen AGS28AWF Gas Dryer
Speed Queen dryer burner lights but does not dry clothes
  • Speed Queen Master
  • 3,740 Answers
This is a symptom of a severely clogged up vent or dryer passages.
Remove the vent duct hose from the back of the dryer and see if the problem persists. If it workes normally clean out the ducting and the through the wall flapper vent.
If the problem persists then remove the lint filter and inspect the air passages inside the dryer. Also check the exit hole where the vent duct connects for lint buildup. Use a crevice tool / vacuum to clear all dryer passages. If necessary use a folded coat metal hanger to assist in removing lint build up.
Wash the lint filter with whie wine vinegar and then soap and water to remove the dryer sheet particulate matter that builds up on the lint filter.
If the burner lights but goes out after 30 seconds then the flame sensor on the top of the burner assy ducting is bad.
Thanks for using FixYa.
Kelly
Posted on May 13, 2010
Testimonial: "Did not think of the burner assy ducting. All other ducting has been cleaned."
Taking to long to dry clothes
How long does it take you to dry your clothes? Normally, it takes 50 minutes (1 cycle) to 1.5 hours to completely dry clothes. However, if it's taking you at least 3 cycles (probably 2.5 to 3 hours) to dry a single batch of clothes, then, there might be a problem with your dryer's igniter.
Jan 09, 2014 | Speed Queen AGS17AWF Gas Dryer
Hi I have a dryer (Speed Queen) and I took off the front panel and cleaned everything and even in back, When I turn it on, I see the flame, But it does not get hot enough inside to dry the clothes, Is...
Clothes not drying, but dryer runs & heats
1. Defective operating thermostat---test thermostat,, replace if defective
2. Fan or it's pulley loose on shaft--tighten set screw
3. Incorrect heat or timer setting--reset timer
4. Clothes too wet when placed in dryer--wring clothes before putting them in dryer
5. clogged lint screen or duct ( little air motion)---clean
Sep 21, 2011 | Speed Queen AGS68AWF Gas Dryers
The clothes wont dry till 4 hours. it take 5 hours to dry clothes. how i can improve the drying system?
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 07, 2011 | Speed Queen AES28AWF Electric Dryer
My speed queen dryer (model 170) is over heating. Clothes are extremely hot to the touch and wrinkled.
check the dryer vent to make sure nothing is blocking it, Hot clothes and wetness is usually caused by venting problems,, if the moisture and air can't leave,, you end up with your problem
May 27, 2011 | Speed Queen Dryers
Speed queen dryer takes twice as long to dry the clothes LGS27AWM3080 1003002387
disconnect vent tube and run a load of clothes, as it sounds like the vent tube is restricted. if that does not help then you will need to clean the dryer from the lint screen to the back of the dryers vent, where you hook up the vent tube. Hope this helped Tim
May 24, 2011 | Speed Queen AES17AWF Electric Dryer
Speed Queen gas dryer model #AGM499W. Replaced the igniter but did not fix the problem. Dryer will not heat.
burner may need to be vacuum out or blown out, also could be the thermo coupler. Hope this helps tim
Sep 02, 2010 | Speed Queen AGS28AWF Gas Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Dryer is not drying clothes dry
My Maytag Neptune isn't drying my clothes
Oct 14, 2009 | Speed Queen Dryers
Speed queen gas dryer uses pay cards
overheating and shutting off,
usually is a blockage in the venting
check the exhaust lines to the wall vent/exits, there may be lint build up in those dryers that are shutting off
Aug 28, 2008 | Speed Queen CGS68AWF Gas Dryer
Speed Queen AGS28AWF Gas Dryer Logo
265 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Kristy Heard Duke
Kristy Heard Duke
Level 1 Expert
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
