Toshiba satellite A215-S4807 3years old, running Vista . Problem: although computer boots up, the screen is dark. Of a light is shine on the screen, I can see the desk top icons. I checked output (F5) key is going to the screen. Sometimes I can catch it during reboot, by pressing F12 and it might be visible for a while not often though. is dark most of the times. Do you think it needs a new video card? Thanks for any assistance wa2c@ATT.net
    President:
  • 548 Answers
No. Try to check the inverter of the LCD. The best and safest solution is to send it to a specialized workshop for a complete diagnosis. There are 2 things that could be broken, the lamp, or the inverter. Check them both. Cheers
Posted on May 12, 2010
Blank screen "BOOTMGR is missing" for toshiba satellite A215-S5837
I would assume this may have Windows XP or 7, see if you can find the recovery disk for your machine. One of the things you can try is use the CD as your boot disk (you may need to enter the BIOS or SETUP to change the boot order...there will be a key to hit when you see the Toshiba splash screen when you first boot the machine...it will say press "<some key here>" to enter setup.)
Once you boot from the disk I would try getting to a command prompt and running the following command: chkdsk c: /f /r
This will scan and repair any bad sectors on your hard drive and if they can be repaired it may make your machine bootable again. If they cannot be repaired, it may be that your hard drive is dying. Either way...if you get into the machine (even from the boot disk) if you can see the drive, I'd recommend backing up whatever files you can, because if the drive dies, you will lose your data
Feb 28, 2013 | Toshiba Satellite A215-S5837 Notebook
WHEN BOOTING THE TOSHIBA SATELLITE A215-S5837 I hear two beeps and get a dark screen. I can press f1 and go into safe mode but don't know what to do next. The error message is "resource conflict...
These beeps are error code and two short beeps during start up normally refers to RAM or memory not being detected. You can try to reseat the RAM modules or ask someone who knows how to do it. If it will still be the same, it means that the RAM is defective and consider replacing it.
Cheers!
Apr 07, 2011 | Toshiba Satellite A215-S5837 Laptop
My Toshiba Satellite A215-S7428 seems as if it's on, but the screen is blank. I have removed the battery several times. It usually takes a while to boot up. I have had this problem before and removing the...
It could be a sympton of display cable failure or the display has failed, try plugging into an external source such as a monitor or tv and then try booting, if you get a display then it is the notebook screen or cable that may be faulty, hope this helps.
Keith
Aug 06, 2017 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A215-S7422 won't boot-up stuck with boot screen the bios is ver.1.00 need help how to make it boot up again,
My Toshiba A215 starts up but won't boot from any source_CD,external floppy, hard drive,etc.. I swap memory,CPU,hard drive ,nothing works,have any one got any solution?//
THANX
Sep 17, 2010 | Toshiba Satellite A215-S7422 Notebook
Toshiba Satellite A215-S7407 ram upgrade
Try to disconnect the new ram you just bought one at the time to see which one is defective. Also, 32 bit operating systems won't detect 4 Gb or ram, but they will show 3 Gb (even though they will use all 4 Gb). To resolve this issue, make sure that if you are using windows Vista to download the latest service pack 1.
Apr 03, 2009 | Toshiba Satellite A215-S7407 Notebook
Toshiba satellite a215-s7422 laptop wil not turn on
It sounds like the motherboard is bad. There is no power being sent to the fan and that means that somewhere in the the mother board is not sending the info.
Jan 31, 2009 | Toshiba Satellite A215-S7422 Notebook
My Toshiba A215-S4747 Crashes every time I move it.
This sounds like the Toshiba Blacvk Screen of Death issue with early A215 models. Re-boot and hold down the F2 key to bring up the BIOS screen. If your BIOS version is less than 1.9, you must update the BIOS.Go to the Toshiba support site and search by model. If your BIOS is ver. 1.9 or later, then go to the power opetion settings and set BOTH the minimum and Maximum power to 100% for BOTH battery and AC. That will fix this about 90% of the time.
Dec 16, 2008 | Toshiba Satellite A215-S4747 Notebook
Computers & Internet Logo
David Payne
David Payne
