Question about Samsung Computers & Internet
The blue light is blinking on the bottom of the monitor but the actual screen is not coming on.
  • interfaith_r May 12, 2010
    All I did was switch the monitor to another computer. It was always working with the blue light blinking. For some reason the screen will not come on but the power is on. I have a samsung933
  • 242 Answers
This seems to be Display issue with malfunction of Ram.
Reboot the computer and keep pressed "F" and "J" key together. If the display comes up it need attention on RAM.
If display still does not comes up then the Display Cable of the monitor needs to be replaced (Not the power Cable).
Thanks
Jimmy
Posted on May 12, 2010
  • Jignesh Khare
    Jignesh Khare May 17, 2010
    IF you try what i suggested you, you will definately will come out of this problem.
    Top Expert:
  • Samsung Master
  • 75,817 Answers
The blue light blinking is an indication that an electronic fault has occurred in the monitors circuit board, have the unit diagnosed by a service facility or just replace it which is almost always cheaper than a repair, average repair cost is about $200
  • yadayada
    yadayada May 12, 2010
    good luck on this, but u will end up replacing it.
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: monitor do not want to come on
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 22, 2009
ginko
  • 19396 Answers
SOURCE: Blue blinking light
  • Video cable.
  • Motherboard.
SOURCE: VL 1919 power button blue light blinks and screen
Yea I fixed it ..bought a new monitor......I tried the old monitor on two other PC's same problem.....
Posted on Nov 24, 2009
No image , transmitter light comes on in reverse . definetly power to both units .
Troubleshooting Peak Wireless Backup Camera Monitor ...
https://www.etrailer.com/question-8083.html
Troubleshooting Peak Wireless Backup Camera Monitor LED Blinks but No ... Select Your Vehicle .... the blue light on the monitor blinks continuiously and I have no picture on the monitor? ... If so, it will only come on when the truck is in reverse. ... still blinking and you have no picture, then you need to look at the transmitter.
4UCam Backup Camera Test Cases
www.4ucam.com/backup_camera_tests.html
We do not have all different kinds of RVs, tailers and so on for the actual testing. ... for under 30 feet), the 8907T/8908T comes with a transmitter which is detached from the camera. You can fix the ... Wireless Car Backup Camera Series ... reverse gear, thereverse lights go out and the camera stops sending an image. At the ...
Dec 28, 2015 | Cars & Trucks
Black screen and blinking blue light
blinking blue lights means the monitor is stand by.for the black screen
you should check your cabels from monitor to computer.they should be seated tight.if still no picture your videocard is proberly brooken.
it should be point out at LCD-monitors are fragile.
Apr 20, 2013 | Samsung SyncMaster S22B150N - LED monitor...
Hey Experts! I need assistnace. My Samsung 2043BWX 20" monitor is black (or blank). I do have a flashing blue LED next to the power. When I plug the monitor in a power supple without being connected to the...
Actually, the ultra high voltage 'charger' for the florecence (a.k.a. your back light)has gone Kaput...
If your lucky, someone will have a monitor like yours that has the back light come on, but no picture (should get a similar blinking light situation, but a different code. Like... blink, hold, blink blink, hold, blink). In this situation (if your comfortable doing it) you can swipe the exciter from that monitor and put it in your monitor. Obviously this is a more economical way of repairing the monitor.
Just to be on the safe side (as the repair is blindingly easy. 6 screws, pop out, pop back in) DON'T touch any of the back side components. You WILL shock the supreme **** out of yourself. Between the heavy duty capacitors and the ultra high gain transformers on those things you could jump start a bus. So don't be fooled... those little transformers pack a mean sting.
Hope this helps...
Oct 11, 2010 | Samsung 2043BWX 20 inch Monitor
Nov 23, 2009 | Computers & Internet
The screen will not come on
i think lose power
i hope i can solve your problem
Sep 02, 2009 | Samsung SyncMaster 730MW 17" Flat Panel...
No Screen on monitor, GREEN light comes on, blinks once, then off
put a vedio card in your computer then, restart your computer.
Jun 16, 2009 | Gateway FPD2185W 21 in. LCD Television
No picture - blinking blue light. My daughter was
There are a few things you can check. First, try to see if the monitor cables are firmly connected on both sides (computer and monitor) no need to remove any cable for now just check the monitor cables (ends should be blue or white on both sides) Then check if you got an imput button on your screen (like all TV and some monitors now has) This input gives you the choice between a few possible connections and it may be on the wrong one. Just cycle trough the input modes and I think you will have your image back. If Still, you dont see anything, try a different monitor or try to connect your monitor on a different PC/laptop. In fact blinking blue could be there because the monitor is awaiting a signal on the input it's listening. At worst it could be because your video chip/card dont send a signal to your monitor, could happen, but imo it's probably not the case.
Jun 08, 2009 | Gateway 1532121 Monitor
ProView 19'' Widescreeen LCD Monitor problems
It guess it is upon the logic board is having problem.
Feb 10, 2008 | Proview PL926WBi 19" LCD Monitor
Computers & Internet Logo
83 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
