Question about Philips DCP750
It doesn't play the disc but it runs and does tick tick tick
All that I know of is, all of the sudden, I put a disc in and did not play... I could hear it running and do tick tick tick...
Can you help?
Thank you.
Jean-PIerre
I have the exact same problem. I looked up all kinds of info on it. When I first got it during a Christmas Holiday season, I had to take it back. The second one gave me the same problems unfortunately AFTER the "return to store" time limit expired. I've read many blogs that spoke negatively about this device and all are true. I contacted Phillips who brushed me off with that "out of warranty" "out of service" date crapp. I even agreed to pay for it just to have it fixed and they couldn't even offer a place for me to send it. One guy said that he found one place out of the states but that it would take six weeks. The bottom line is, dont ever buy a piece of CRAPP with the Phillips name on it ever again! Sorry Buddy!
Posted on Jul 07, 2010
Are blu ray stops payling in the middle of movies for no apparent reason
One of the possible reasons is that your Blu-ray player is unable to read the disc. Check to make sure the inserted disc is clean and not scratched on the playing side. If so clean the surface of the disc or use an alternative Blu-ray disc to verify. ... Only Region B Blu-ray discs and Region 4 DVDs are compatible.11 Oct 2017
Blu-ray Player cannot play discs - Samsung
www.samsung.com/au/support/skp/faq/1045337 blu ray stops payling Google Search
Oct 23, 2017 | Sharp BDHP20U Blu-Ray Player
Displays no disc when Cd is player
Hello
Put it an other good known disc, which the set has played without any problem at all. If it also doesn read it, and displays no disc, the Laser Picku unit of your set has damaged. Put in a lens cleaning disc into the player, and play it for at least three times. If the fault is due to accumulation of dust or durt, the cleaning disc will clean it, and your set will be OK. If not repalce the Laser Picku Unit, sith same type and number.
The lens cleanig disc can be bought from most of the electronic sparpart selling shops at your town, and won't cost more. OK.
Jan 23, 2012 | Sanyo DC-DA1000 CD Shelf System
I moved my xbox360 while disk spinning in it,the current game doesn't work so good anymore,and now it makes tick-tick noises sometimes when game disks are playing.It reads all disks,theres no problem...
The users manual for the xbox 360 says to never move the console with a game inside. In doing so, you probably knocked the disc off the spindle causing it to grind against the laser and laser assembly. The ticking noise is probably from the motor that moves the laser back and forth across the disc. A spring may have come loose from the motor causing it to click as the screw occasionally slips from the guides. This should not cause a problem, however the plastic inside the motor may wear out causing the "open tray" error after some time in which case a repair will be necessary.
Oct 03, 2011 | Microsoft Xbox 360 Console
Just played a movie, put a new movie in and is now says "no disc inserted". Whats up with that?
Could be a faulty disc. Try another one, or the one you just watched. If it works, you know that it was the movie, If it doesn't run a disc cleaner through it, and then please rate this answer for me.
Sep 17, 2011 | Panasonic DMP-BD60K Blu-ray/DVD Player
Says no disc in the player,had the player three years now and all of a sudden it says this
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Aug 17, 2011 | Sony BDP-S300 Blu-Ray Disc Player
When i put in a dvd into my player, it says no disc, and won't play, when it does accept the disc, it doesn't play it, then a "C:13:00" starts blinking. I should be able to just put in a...
It's most likely dirty, though it could be failing. The lasers have an average life span of 3 years, under normal use.
Several companies make CD/DVD laser lens cleaners. You want the kind with optical quality brushes on the bottom side. You simply put it in, let is spin up and play, then take it out. It may not play the first couple times you put it in, but it will be cleaning the lens and pickups.
If that doesn't do it, I'd start looking at sales for a new player.
Jul 05, 2011 | Sony Televison & Video
XBOX Guitar Hero World Tour- Disc Unrecognizable
I know exactly what your problem is. I am huge nascar freak so you know i gotta have the games. Well it just so happens that i was playing on xbox live on my first month and have been hearing a lot of people saying how their console says the same thing well i looke for the answer. It turns out that after lots of playing for long periods of constant play time(3-8+)hrs. without freezing and getting any break at a time. Can sometimes put a ring some times invisible around the disc almost always permanently damaging the disc.
Jun 23, 2009 | Activision Guitar Hero III: Legends of...
My ps2 slim says disc could not be read and it makes a ticking sound
The ticking might be coming from the laser itself. It might be getting too closer to the disc and trying to go farther than it is possible. With the disc out, push the laser from the side all the way away from the center and make the console think that the lid is closed. This may take a few tries before it works. If the problem does not seem like it is coming from the laser you may have a stripped wire that is sparking and should be taking in to be repaired. The latter is possible but VERY rare.
Nov 14, 2007 | Sony PlayStation 2 Slimline Console
Philips DCP750 Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
