Question about Kenmore HE2 Plus Front Load Washer
My Kenmore front-loader (model 417.44042400)has
My Kenmore front-loader (model 417.44042400) has stopped working and it's only five years old!! It turns on and starts to fill with water, but the drum won't turn, so it just sits there. When I advance the dial to the spin cycle, it sounds like it's trying to drain, but it won't spin.
5 Suggested Answers
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 1937 Answers
SOURCE: I have a model 417-44042400 front loader. I
See the following site for Sears manuals for your washer:
They are PDF files that can be downloaded and printed.
http://www.managemylife.com/mmh/owner_manuals/search?query=417.44042400
Posted on Apr 05, 2010
tunde007
  • 2382 Answers
SOURCE: Washer does not spin the
Hi, if it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Posted on Dec 14, 2010
  • 6277 Answers
SOURCE: kenmore-top loader model #110.22422100 wont enter
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 16, 2011
Kenmore model 116 58015700 power mate beater bar stops working
Just pulled mine apart and the bearing on the belt side is toast. In the past five years I have had several items fail due to less then optimal bearings. Including a transmission in a Vibe and a front load washing machine.
Mar 30, 2013 | Kenmore Vacuums
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
Jan 30, 2012 | Washing Machines
My Kenmore front loader washer is 5 years old. It
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 16, 2009 | Kenmore Elite 45986 Front Load Washer
My Frigidaire GLTR1670A front loader hot and cold
sears parts direct carries a lot of parts can be accessed online can start there or just search for frigedaire part number
Dec 10, 2009 | Frigidaire GLTF1670A Front Load Washer
Stopped during wash 40 cycle and start and pre wash button flashed five times paused and flshed five times again and wahser door is quite hot
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to Applianceaid.com where they have very good and complete trouble shooting and repair information on front loaders. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it.
Nov 25, 2009 | Dryers
Trying to figure out Cu. ft. capacity
hi wanda, most top load whirlpool units, they make the sears kenmore models, are around 3.0 cubic feet.
its not that important for a top loader, but when going to a front loader thats how they rate them.
what i would recommend is you buy a unit that will do the laundry that you will need to do for the next 15 years.
what i mean is if you have 2 or more young children, that you will be doing laundry for the next 15 years, then a full size front loader would do you good. size 3.5 c/f or larger, like a whirlpool he4 or he5.
if it is just for 2 people then a smaller unit would be better, like a whirlpool duet or sport model.
the reason for the choice is a front loader needs to be filled up for it to work properly. doing smaller loads in a front loader will cause them to shake and not work as well.
now be ready as the new washers will cost about 1,000 bucks.
another suggestion for 2 people would be the whirlpool cabrio top loader. i like them alot and they have very few parts to fail and have a good reliability.
good luck and happy shopping.
p.s. remember sears will match prices and give you 10% off the best price!!
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Leaking front loader
the most likley place is the front rubber boot it can get a small hole in it and leak if the hole is not to large you can clean and dry it and reseal it with silicon rubber sealent
Dec 03, 2008 | Kenmore 44102 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
279 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
