Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
Bluetooth will not connect to phone
I walked into another room with bluetooth on adn out of range of phone. Normally, I hear a bleep to let me know I'm out of range and when I come back into range, I will hear a bleep; the read out on the phone will say something to the effect ~ connected to plantonics. This did not happen last night; went into settings on phone to connect to bluetooth and got message no devise found. H_E_L_P!!
SOURCE: LG Shine won't connect to Plantronics Bluetooth
Take the metal battery cover off and you shouldn't have a problem. it should connect right away. I guess the metal interferes with the connection. there's no need to take the battery out.
Posted on Apr 15, 2009
SOURCE: bluetooth "device out of range or powered off"
I had lots of trouble too. I thought it was my phone. Well here's what you do. First off remove the device completely from your phone. Turn off the phone and take the battery off so it can re-boot. When the phone is powered back up put your bluetooth in pairing mode and get it back on your phone. It should connect without any problems. Now....here is the trick. When you want to disconnect the device(bluetooth) from your phone don't turn it off on your phone. Shut the actual power off on your bluetooth. The phone will recognize this and disconnect the device. The only thing left on your phone will be the bluetooth icon. Being the icon still on your phone it is still in discovery mode and can overtime use up your battery life searching for a device. This is when you can go to your phone and turn off the bluetooth. On your NV 2 go to your bluetooth menu and just use your left softkeyto turn it off. Now there is no connection whatsoever. And to turn it back on do the opposite. Go to your bluetooth menu and turn on your bluetooth. You will see the bluetooth icon. Now you power up the bluetooth and it will connect as soon as it get the signal. This took me 2 weeks of trial and error and other stuff but I am happy now and I hope this solves any bluetooth problems...
Posted on Jun 06, 2009
award462
  • 395 Answers
SOURCE: Bluetooth has lost connection with phone and I can't get it back
You should delete the headset from the "paired devices" list on the phone and completely redo the pairing process, it sounds like the two have gotten into some kind of wierd state.
If you need help with this please include the make and model of your phone.
Posted on Nov 05, 2010
HDI Headsets
  • 537 Answers
SOURCE: I have an LG phone
You want to make sure that there is no other bluetooth interference on your phone and follow the instructions on the link for the Plantronics Discovery 925 (see page 4).
Good luck from Headsets Direct!
Posted on Aug 31, 2011
Iphone 4: I connect to bluetooth headset; walk out of range; then walk back into range...how to have iphone automatically reconnect to bluetooth headset
Sorry to read about your problem, I hope this helps you out.
it will not do a auto connect, you will have to hit your headset button to talk, and then the unit will reconnect. their are some headsets, that will send out a auto connect..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Apple iPhone 3G
I don't know my passkey number or alpha
Pass key is 0000 but reset the kit first by holding down the nokia button till you hear a bleep.
Dec 12, 2010 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Angelcare monitor Model #AC420-P no transmittion between base and monitor. no battery problems in either
Had exactly the same problem but this worked. Never even realised there was a button on the top of the unit!!! It looks like a little LED at the base of the hoop. Happy monitoring.
CONNECTING THE PARENTS UNIT TO THE NURSERY UNIT:
If you lose the connection between the 2 units,turn them both off. Turn ON the parents unit and
press and hold the MENU button ,the "out of range"indicator will flash and you will hear a
beep.Turn ON the nursery unit and press and hold the top button of the nursery unit to reconnect.
The Tic light flashes.This normally happens within a few seconds and you will hear a bleep
to confirm it. If successful, the parents unit display will first show the channel of transmission (C1
to C8), which will be replaced by the room temperature and icons for all activated functions.
Note : The connecting process should be done within 30 seconds. If longer, the operation will be
ignored and you will have to start over.
• PAGING: If you want to locate the parents unit, press the top button of the nursery unit.
Aug 10, 2010 | Toys
Angle care wont connect to the base
Manuals: http://www.angelcare-monitor.com/Canada/en/help
Had same problem - here's what worked for AC401 (from manual):
CONNECTING THE PARENTS UNIT TO THE NURSERY UNIT: If you lose the connection between the 2 units,turn them both off. Turn ON the parents unit and press and hold the MENU button ,the "out of range"indicator will flash and you will hear a beep.Turn ON the nursery unit and press and hold the top button of the nursery unit to reconnect. The Tic light flashes.This normally happens within a few seconds and you will hear a bleep to confirm it. If successful, the parents unit display will first show the channel of transmission (C1 to C8), which will be replaced by the room temperature and icons for all activated functions.
Dec 20, 2009 | Angelcare 2009 Movement Sensor Baby...
I droped the monitor last night and I only get to dashes appearing on the screen and it wont pick up any sound!
Manuals here: http://www.angelcare-monitor.com/Canada/en/help#tabs-2
Nov 26, 2009 | Angelcare Deluxe Movement Sensor & Sound...
I have asony phone but just got a merc with a nokia blue tooth fitted how can i connect my phone
Search for bluetooth device from your phone, you should find ck-7w press connect then the passcode is 0000. make sure the ignition is on or press the Nokia button. If this dont work then hold down the Nokiabttton till you hear a long bleep, this will wipe all previous paired phones. then try above again.
Oct 18, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
My parent unit wont do anything, it just flashes with the nursery unit simble and i can not access the menu.
Oct 16, 2009 | Angelcare Deluxe Movement Sensor & Sound...
How to connect LG cookie with Nokia Bluetooth BH 101
Put your Nokia Bluetooth BH 101 into pairing mode - this is normally done by pressing and holding the power key for several seconds. An alternate bleep will sound with a flash light to indicate that you are in pairing mode.
Now using your Cookie, press Menu > Settings > Bluetooth > Search
Your Cookie will find the Nokia BH101 bluetooth headset and then it will ask for a pass code. This is usually four zeros (0000).
You should now be connected!
Apr 10, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Bluetooth connection
First I would need to know the model Bluetooth you have so I could tell you what to do to reset the headset. You can always reset a bluetooth headset to repair it to another device. Normally though to reset a bluetooth headset, you would have to power the Bluetooth device off and then press and hold the device to get it in pairing mode. Usually when in pairing mode the device's light usually stays lit a solid color such as red or purple, or it flashes two different colors simultaneously. At that point you can get your device to find the headset (make sure that you device is bluetooth capable, is on, and is visible to devices) and then pair it. There is always a passcode or pin associated with the headset which creates a secure connection between your device and your bluetooth headset. The default pin code is 0000. Hope you get it working, if it doesn't shoot me a message with the make and model of the bluetooth headset and I can walk you through it.
Dec 17, 2008 | Cell Phones
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
