Question about RCA R52WH73 Projection Television
Auto convergence feature doesn't work
How can I reset the t.v. to default settings (factory setup)? Unplugging the set doesn't work.
  • 1,476 Answers
You have defective convergence. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on May 13, 2010
What is a 116-386 error code
Resetting to Factory Defaults / Clearing the Memory
You can selectively clear information stored in your machine's memory.
  1. Press Menu on the control panel until Maintenance appears on the top line of the display.
  2. Press the scroll buttons until you see Clear Memory on the the bottom line and pressEnter.
  3. The first available menu item, Paper Setting, displays on the bottom line.
  4. Press the scroll buttons until you see the item you want to clear.
    • Paper Setting: Restore all of the Paper Setting options to the factory default.
    • Copy Setup: Restores all of the Copy Setup options to the factory default.
    • Fax Setup: Restores all of the Fax Setup options to the factory default.
    • Fax Feature: Cancels all of the scheduled fax jobs in the machine's memory.
    • Advanced Fax: Restores all of the Advanced Fax setting options to the factory default.
    • Sound/Volume: Resets the sound and volume settings to the factory default.
    • Machine Setup: Resets all of the system settings, such as the machine ID, date and time, display language and save modes, to the factory default.
    • Set Report: Clears all records of your faxes sent.
    • RCV Report: Clears all records of your faxes received.
    • Phone Book: Clears the speed dial or group dial numbers stored in the memory.
  5. Press Enter. The selected memory is cleared and the display asks you to continue clearing the next item.
  6. Repeat steps 2 and 3 to clear another item.
  7. ORTo return to Standby Mode, press Stop/Clear.
http://www.support.xerox.com/support/enus.html
May 08, 2015 | Office Equipment & Supplies
Power off
Just look in the menu options for "Sleep mode" and set it to OFF! If that doesn't work, try unplugging the television for an hour or set. That usually resets it to the factory default setting. You might be able to reset it by looking in the menu options and select "Factory Reset" and that should reset the Sleep mode. Hope that helps!!
Oct 20, 2012 | Panasonic Viera TH-42PX80U Plasma TV
How do I reset my d-link 615 ? Problem is that pppoe is not lit. Hopefully this would fix the connection which was working fine until it stopped.
If unplugging the power and leaving it off for a minute or two doesn't fix your problem you can reset it to the factory default by using a pen to push the reset button on the back. Factory defaults are on the bottom of the router. You will have to change all your settings back to the way they were though.
Apr 12, 2011 | D-Link DIR-615 Wireless Router
When I attempt to copy a document-8in. X 11in- and have the copy menu set to -"original size auto detect,the printer persistently prints a smaller document size,usually 4" X 5". I have...
Try to reset your Lexmark X4650 settings to factory defaults. On the printer operator panel, press Setup -> select Defaults -> select Set Default -> select Use Factory -> press OK. Then try to make a copy again.
I hope this information has been helpful. Thanks.
Jan 06, 2011 | Lexmark X4690 Wireless InkJet Printer
I forgot my security key/pass phrase... nothing I do is coming up?
he router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
To perform a hardware reset on your Linksys router, follow these steps:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
Aug 23, 2010 | Linksys Wireless-G WRT54G Router
How to reset convergence? on mitsubishi ws 55511, has a shadow colored blue or yellow
There is an option in the user menu on the tv. Using either the remote or control panel on the front of the tv, press MENU then select SETUP. After you choose SETUP go to the 3rd column with the 3 icons. Here you can adjust the red or blue color or reset the convergence back to factory default.
After a few years the set will begin to show increasing problems with the convergence settings. When you can no longer adjust either red or blue horizontally or vertically an IC replacement will be needed. Your set uses (1) SANYO stk393-110 and you want to make sure it's SANYO and not a knock off brand as those usually fail prematurely.
Jan 23, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My Belkin N1 (F5D8232 ver.1.0) reset's randomly
try upgrading the firmware. if it doesn;t help, the router is brick.
Sep 10, 2009 | Belkin N1 Vision Wireless Router
How to use the Zoom
I assume you mean when pressing the W or T buttons the zoom feature does not work. Try to reset the camera to the factory default settings and this should enable the zoom feature to work again. To do this go to Ok button and then to Mode Menu - then to Setup tab and then right arrow to Reset. hit the right arrow and you will see Reset Yes or No. Highlight Yes and press Ok. Camera should be in factory settings and zoom option will function.
Nov 13, 2008 | Olympus Stylus 600 Digital Camera
How to reset defaults Panasonic HD PT-47WX53G TV/picture
First of all are you sure you were in the factory menu this step requires alot of known how!!!!!! By using your hand unit only customer controls can be reached unless you know factory menu setup. Which starts like this ,make sure antenna to cable then go to menu set sleep timer to 30 mins exit out now enter ch 124 then press v- down on tv you should now see on top CHK ,also these sets have double convergence patterens.if you were in factory set up for more information look in www.freelists.org techassist/09-2005 .let me know if you still need help.
Nov 14, 2007 | Panasonic PT-47WX53 47" Rear Projection...
RCA R52WH73 Projection Television Logo
114 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
