Question about Delta Machinery Sanders Sanding Center - 31 - 300
Should I buy an old Delta sanding Center? Is it wise to buy an older Delta sanding center 31-730F Not all parts are still available. They want $250.00 for the sander
  • 623 Answers
If it's the kind with a round disk sander and a wide belt sander, as far as I know belts and disks are still available. There is not much else to wear out. Make sure you test it before purchase.
Posted on May 13, 2010
Where can I find a replacement chuck key for a Delta 11-950 bench press?
No you don't have to buy Delta's chuck key. MOST drill press chuck keys are very similar but if you do order another companies key and it doesn't fit, you may be stuck with it. If you have a local tool repair center that carries keys you can try one and if it don't work, return it.
The Delta part number for your chuck key is 1313104. It is avaliable from Dewalt (they own Delta) on their service website at http://servicenet.dewalt.com. You can also get it at aftermarket sites like www.ereplacementparts.com for only $11 plus shipping.
Sep 15, 2012 | Delta Machinery Drills
How do I change the sanding belt on a 31-300 delta sanding center?
it comes with a edjustable screw on it.you will need to adjust screw for it to fit on the right way.
Feb 27, 2011 | Delta Machinery Sanders Sanding Center -...
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
I NEED A REPLACEMENT GEAR PART NO 1347788 FOR A DELTA 31-780 SPINDLE SANDER
The link below includes the schematic, part list, pricing and ordering info for toolpartsdirect.com
Delta also offers this model in 2 other variations, 31-780 type 1 and 31-780 type-2. Both of this are also available from the page this link will take you to. The part you are looking for is $13.33 and they show 4 in stock.
Have a great day.
Dec 28, 2010 | Delta 31 - 781 Sanding Spindle Set for 31...
I bought my above ground swimming pool package in 1990. My Hayward sand filter is a top mount and has a lateral assembly w/center pipe in side of it. The pipe is broken at the top and I need to purchase a...
I believe that the owners manual has a parts listing to help you distinguish the part that you will need to buy. However, if your pool filter was purchased in 1990, you are probably going to need a new filter. Most do not last over 20 years.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
May 01, 2010 | Hayward SAND FILTER, PRO SERIES
Will Delta Belt fit Mastercraft Band Saw
If you still have the old belt, take it to a well equipped hardware or auto parts store for a replacement. If the previous belt is missing, you will need to measure the pulley 'V' width at the top of the 'V', the center to center measurement of the two shafts, and the outer diameters of the two pulleys. Hope this helps!
Apr 15, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
I require part #1320210 for a 6"delta mod #23-681
The new part number is 901912. You will have to contact a Dewalt service center to see if they can rustle one up for you. They are no longer available directly from Dewaltservicenet.com but you may get lucky contacting a service center.
Jul 02, 2009 | Delta Grinders
Changing the sanding pads
You use a 1/2 inch socket wrench to remove the nut at the top of the spindle shaft, slide the old sanding sleeve off and the new one on.  Replace the nut.  You may also have to insert a different size table insert if you are changing the sleeve size.
Instruction manual is available free at: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/a20932,sa350k.pdf
May 30, 2009 | Delta SA350K Shopmaster Boss 1/4...
Water pooling at base of delta waterfall faucet spout
I have the same problem. The part that is needed is found with a simple Google search for "Delta Waterfall RP22934 O-Rings"
Simply Slide the collar up at the base of the spout where it swivels.
Gently open the now exposed split plastic retainer so that the tabs near the bottom are pulled from their holes.
Lift the spout off the base to expose the o-rings.
Replace with the new o-rings and apply o-ring grease.
Re-assemble and enjoy a dry sink area.
Nov 25, 2008 | Delta Faucet Delta 172-SSWF Waterfall...
Delta Machinery Sanders Sanding Center - 31 - 300 Logo
220 people viewed this question
Top Delta Machinery Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Delta Machinery Measuring Tool and Sensor Expert? Answer questions, earn points and help others
