Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
How to adjust govenor on lawnboy mower? - Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Where are the jets on a lawnboy 10247 push mower that purges when started ?
I need a little more information such as the engine manufacturer and the numbers off the tag on engine and what do you mean it purges do you mean the engine changes speed without you moving the throttle. This could be caused by restricted air cleaner or loose carburetor or either partially clogged carburetor
Jun 03, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Lawnboy 10665 won't self-propel and impossible to push
If you have the smell of rubber burning the belt isn't gripping. Make sure that there isn't anything stopping the wheels turning like old grass or even a piece of twig. If their clear try adjusting the tension on the drive pully.
Jun 28, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
Lawnboy help
ck. governor linkage connections
Jun 18, 2013 | Garden
Lawnboy Commercial Mower - idle speed adjustment
did you have the governor arm off of the motor
Jun 06, 2013 | Garden
Rough low throttle on Lawnboy Dura Force Pro 6.5
IT HAS A WEAK SPRING THATS ALL IT IS
Sep 28, 2009 | Garden
I have a 1987 commercial lawnboy walk behind mower that has stopped running. I gradually lost power over the summer and now it will not start. I have installed a new plug and filter earlier in the spring....
I would try and remove carb and clean it thuroughly. You can soak the parts in solvent or equivelant. The carb would be right after the air filter tube to the intake of engine.
Aug 25, 2009 | Garden
How do i install the spring throttle on a lawnboy 10323
take the air filter off the spring is attached to the govenor rod to a fixed arm once attached the arm can be bent to tighten the spring or bent the other way slow the speed tighter the spring faster the speed there is another rod attached to the govenor rod to the throttle
Jul 01, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Rerunning the belt on an o6 self-propelled Lawnboy
You may have to loosen the adjustment a bit to let the transmission tilt farther forward. Do not loosen the other nut on the adjustment, that way you will know how far to re-tighten the one you loosened when you have the belt on.
Apr 12, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
572 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
itsman
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
