Question about Bosch 24 in. SHX46A05UC Built-In Dishwasher
Bosch shx46ao5uc takes 3 hours to cycle. Whats the problem
  • Bosch Master
  • 2,605 Answers
Hello and welcome to Fixya.
If it is taking 3 hours to complete a cycle as you stated, I would counter that with a question. Is the water entering the machine hot or relatively cold ?
If it is cold, this will be a major factor in the unit taking a very long time to complete a cycle. Each time the unit has to fill the heater must then heat it until satisfied ( usually 85degrees celcius) , this can take 5 minutes or 15 minutes each time depending of course on the inlet temperature, hence extending the cycle by potentially an hour or more ( a normal time is typically 90min to 2 hrs. )
You can try running the hot water at your sink tap to insure the cold water is out of the lines just before you turn on the dishwasher. If it is what I suspect, the control, this won't make any difference but it's worth a try.
If on the other hand the water is good and hot entering the machine, you likely have an issue with the control. repairclinic.com carries them as part # 1102296 at a retail price of $185.65US. as I type this today May12,2010
however, I have a suggestion as to identifying the culprit, thus confirming or dismissing the cause...
since the issue with your Bosch dishwasher potentially lye`s within`the electronic timer/control as I alluded to, specifically the heater relay solder joint. You'll need to access the control for a visual inspection ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). This is possibly one of the reasons why it runs for 3hrs unless pressing the two buttons for "cancel".
To inspect and possibly repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit runs & runs ( because it can`t heat to advance or until canceled ) trying to heat the water.
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question's, let me know if I can assist you further. I will look for your reply in regards to the water temp question I had.
Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied.
Good luck.
macmarkus :)
Posted on May 13, 2010
I have a Bosch Exxcel front loading washer dryer and can't remove the detergent drawer to clean it, plus all washing cycles take well in excess of 2 1/2 hours to complete. Annoying
Normal wash loads do not take over one hour, but you have to set them on clean any stain option and it will take 107 minutes to wash.
It sounds to me like your washer needs servicing by a trained Bosch serviceman, because it should not do this.
Jun 26, 2017 | Bosch Washing Machines
WHIRLPOOL ADG 6340 ix - At start and during the cycle water drains in pulses and for long time and water intake is in pulses and for long time. The cycle finishes OK but it takes long time, 30 min cycle...
since the water drain is on a float be sure there is no blockage of the screen drain area in the bottem of the dishwasher under the lower rack.the make some cleaner rinses to clean out the screen.
Feb 21, 2014 | Bosch SHX5AL02UC Dishwasher
Dishwasher takes 3 hours to run through programme
3 hours isn't "extremely" long. If you run a normal cycle, it should run about 2-2:30 hours normally with the drying cycle. Now if it's over 3 hours, that would be a problem. Make sure that when you open the door that there is a lot of steam coming out, because that is the only thing that can extend the cycle is if the dishwasher isn't heating the water. Unfortunately this is a very common issue and it means that your control board inside the door has failed. There is a relay on the board that shorts out. This relay sends power to the heater, so when it fails the dishwasher doesn't wash well and it will run forever trying to heat the water which will never happen.
Sep 10, 2013 | Bosch Dishwashers
Our dishwasher takes about 3-4 hours to run a cycle. My brother has the same model and it takes about an hour. Is there an adjustment that we can make to correct this? Thanks, Karla
make sure that your filter in the bottom is clean and if you are using the automatic wash cycle, it will wash until the water is clean. Sometimes it will take an hour, sometimes it will take close to 2 depending upon the level of dirty dishes in the dishwasher. And don't rinse! They work better on dirty dishes.
Jan 05, 2011 | Bosch 24 in. SHX46A05UC Built-In...
3 hour cycle - dishes not clean - bosch dishwasher
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jul 18, 2010 | Bosch 24 in. SHV46C13UC Free-Standing...
Bosch Nexxt 300 washer takes hours to do a single load
We had similliar problem. We were overloading the wash barrel and using too much soap. The soap was foaming causeing the washer to add rinse cycles hinse more time to the cycle. Make sure your soap has the HE ( high efficiency ) label on it. Hope this helps.
Jun 27, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Specks of "sand-like" food on my dishes; water not draining
I bought a replacement filter and that dramatically cut down on the amount of "specs." Now there are only a few in some of the glasses. I also cleaned out the drain underneath the screen, there were peas and corn in there, I just used a shop vac to **** them out. Seems to be much better now, I think a good inside cleaning of the washer will help out too. Hope this helps...
Mar 03, 2009 | Bosch SHU9915UC Dishwasher
Cycle time
First, read the manual before touching the settings. You need to set it up carefully but don't always change it unless you understand it. Secondly, if there's no change, call the Dealer.
Dec 18, 2007 | Bosch SHU3305 Dishwasher
Bosch dishwasher
Bosh shu 43 built in take 3-4 hours to cycle
Aug 04, 2006 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
983 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
