Hello there, i am using ulead video studio v11 plas. I have been working with is for moths but since yester it doesn't work. i can not open the ulead on the desktop. it says "The security information is invalid or had been modified. This program will be terminated"
Could you please help me in this case?
Greetings
from Tibet
Comments:
Mar 29, 2008
- Hello there, i am using ulead video studio v11 plas. I have been working with is for moths but since yester it doesn't work. i can not open the ulead on the desktop. it says "The security information is invalid or had been modified. This program will be terminated" Could you please help me in this case?
Greetings from Tibet
Mar 31, 2008
- hi, Geno,
thanks for your help. actually i am using vista and finally i could open ulead studio 11 but while it converting the video, maybe after 20 minutes, an error comes up saying"Unspecified error" then it can not creat the movie on disk. do you have any idea?
-   i have the same problem what can i do???????-   Guest
Feb 27, 2009
-   whenever i tried opening ulead 11, it says, the security information is invalid or has been modified, the program will be terminated.-   Guest
Assuming it's windows XP (you didn't say). You could try Restoring back to before the last time you used it. The other thing is to uninstall it, reboot, reinstall it.
upgrade it to corel (ulead) video studio x2. its the same thing as 11 and will still open (.vsp) files so you won't loose any of your current projects.
note: they changed the name from "ulead" to "corel" between version 11 and x2. makes no difference though.
x2 is basically the same as 11, 11.5, 11.5 plus. its graphical interface is a bit different, but if you were used to using uvs 11, you will have no problem.
Set up my EasyCAP usb 2.0 video adapter with audio but when I try to capture video it comes up with...
(More)
Set up my EasyCAP usb 2.0 video adapter with audio but when I try to capture video it comes up with weak or no signal, tried changing settings to video composite and NRSC_M but still no use, any ideas?
I use EasyCap Video Adapter with Audio I connect My VHS Player output to easycap, the Ulead...
(More)
I use EasyCap Video Adapter with Audio I connect My VHS Player output to easycap, the Ulead Videostudio 8 doe not show my playing tape. My connections are good and the usb driver is installed and reported by Windows as working. What do i need I do to make this work? Plz help
Hello I have a ezcap usb grabber I am running vista and installed the drivers as well as...
(More)
Hello I have a ezcap usb grabber I am running vista and installed the drivers as well as Arcsoft showbizdvd 2 I can not get sound from the capture help please before I throw it in the nearest bin
