Question about Sharp Twin Energy EC-12TWT4 Bagged Upright Vacuum
Self leveling platform will not lower.
When foot pedal is pressed the handle will release but the platform does not lower
  • 438 Answers
Hi There,
This is probably being caused by the two little feet on the bottom of the agitator housing. I have yet to completely understand what the purpose of these two feet are, but what happens is that over time the screws that secure them in place begin to loosen, which allows these two little feet to become lodged between the agitator housing (the part the brush is actually in) and the vacuum bag housing (upright part) preventing the agitator housing from releasing when stepping on the foot pedal.
Here's a picture of these two little feet from the parts schematic. You may either tighten the screws, or just remove these two feet entirely from the vacuum cleaner, Other then helping stabalize the vacuum while in the upright position, these don't really seem to much else.
Here's the picutre of the two feet which are circled in red.
If you inspect these feet and they are not loose, then you may have an issue with the handle release pedal itself. Please just add a comment if this did not fix it, and I will be happy to walk you through step by step on how to fix the handle release.
I really hoped that this helped you fix the machine. If you found my repair helpful, please be so kind and rate the repair, or leave feedback for me. This is greatly appreciated by the Fixya community.
Thanks again,
Chris Jones
GoVacuum.com
Posted on May 12, 2010
How do I fix the foot pedal assembly for the handle release on shark vacuums?
You should call cust service. Call may still replace it.
Aug 04, 2014 | Shark Vacuums
Install foot pedal release on riccar 8800 series
It's not hard to do but is almost impossible to explain how to do it. If you can look at one already installed on the shaft holding the pedal you can see how it's done. Visit your local Riccar dealer.
Jan 12, 2014 | Riccar Handle Release Foot Pedal - 8000...
Can't lower handle on Hoover u6432-900 so can't clean floo
usually theres a plastic pedal you would step on to release the handle.... first thing i would try is pushing up (foreward) on the handle and try pressing the pedal .if the pedal wont push down at all then something might have gotten jammed down in it..... at which point you'd have to do a bit of fiddling around with it to see whats keeping it jammed up.....also... there could be something stuck in there thats keeping the handle from being able to move down.... as for the self propelled part.... it probably wont work untilthe handle is lowered... hope this helps
Nov 12, 2013 | Vacuums
Can't lower handle on Hoover wind tunnel vac U6432-900
Anne, Do you mean that when you depress the pedal on the left side of the machine body that you can't get the upper portion to release into a lower mode? Or are you fully depressing the pedal?? As for the switch for the self propelled mode, that's actually just a small button that you move around in the slot of the handle to select which mode you want to use. It's not actually a switch. If you are fully depressing the handle release pedal and it's not releasing, you should take it to the store where you purchased it, if it was a vacuum store. If you bought it at a big box store, then you'll need to take it to some repair shop that does warranty work, if it's within the warranty period of course.
Nov 10, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
I'm a house sitter with this amazing vacuum, but don't know how to operate it in general. I simple need to vacuum the carpet. Please help me.
Unwind cord and plug it in
As you view the back of the machine, the foot pedal release is on the bottom left of the vacuum. Press this with your foot to enable you to lower vacuum into cleaning position.
Turn on and vacuum.
On/off switch is on the handle.
Aug 21, 2010 | Riccar 8955 Upright Vacuum
Hi, pressing the big red foot button on the dc25 lowers the cleaner to the working position,but it wont stand up again. would appreciate some help. thanks. TC
sounds like the ball cradle is worn out, the springs are too stretched to pull the handle release pedal back into place. you can do one of two things, replace the cradle assy, or just lift the red pedal up when you raise the handle
Feb 27, 2010 | Dyson DC25 All Floors Bagless Upright...
Foot latch is broken. need to replace with new one. how does one access to remove the foot pedal latch. By foot latch, I mean the foot lever that releases the upright to lower the handle and begin...
it is accessed from the bottom underneath by the rear wheel. However, If there are and cracks on the pedal release socket area then the base will need replacement. parts are little cost but the unit needs to be completely disassembled.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 17, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
Pedal does not engage anymore
I have the same problem. You will need to replace the handle release pedal, part number 8174899, $7.99 plus tax & shipping. Check with Sears Parts. It's a single screw that holds it in place.
Jun 29, 2008 | Vacuums
Dirt Devil vacuum Release pedal not working
take off the bottom like you are replacing the belt. You will find a little metal clip that controls the upright lock.  It may be lose or broken.
Oct 01, 2007 | Vacuums
Sharp Twin Energy EC-12TWT4 Bagged Upright Vacuum Logo
281 people viewed this question
Top Sharp Vacuums Experts
jasbo
jasbo
Mike
Are you a Sharp Vacuum Expert? Answer questions, earn points and help others
