Question about Samsung Refrigerators
My fridge keeps beeping and showing the super sign in red. what should i do. i have switches it off and on again but the beep doesn stop!!
Remove or break the speaker on the top. You can remove cover on the top, there is round cylinder shape of speaker at the center of circuit. Cover or break.
Posted on Nov 26, 2013
  • Youngho Ko
    Youngho Ko Nov 26, 2013
    remove or break the speaker on the top. You can remove cover on the top, there is round cylinder shape of speaker at the center of circuit. Cover or break.
  • Youngho Ko
If it is a Samsung mine does the same. I have no idea why but have managed to stop it beeping to save us all going mad by taping down the super button into the off position.
Posted on May 19, 2010
Why my fridge freezer keeps beeping four hort beeps
Temperature alarm
If the temperature becomes too warm, an alarm will sound and the temperature display will flash. The temperature the appliance is set at will determine when the alarm is triggered.
The alarm will sound and the display will flash under the following conditions:
  • - whenevertoomuchwarmairflows into the appliance, for example when food is being loaded, re-arranged, or taken out.
  • - wheneverlargeamountsoffoodare being frozen at once.
  • - whenevertherehasbeenalengthy interruption of the power supply. Door alarm
    If the appliance door is left open for longer than approx. 60 seconds, the alarm signal will sound.
Switching the alarm system ON
The alarm system is always active. It does not need to be switched on manually.
Switching the alarm OFF early
Once the set temperature has been reached in the freezer section, the alarm signal stops and the temperature display stops blinking. If the alarm signal bothers you, it can be switched off early.
^ Press the alarm off button. The alarm signal will stop. The temperature display will continue to blink until the set temperature has been reached. The display then stops blinking, and shows a steady reading. At this point, the alarm system is ready again if needed.
Aug 15, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
F&P E521T beeping
If it is beeping, it has a problem other than the beep that needs to be addressed. This is probably outside the skill set of the average person.
May 05, 2014 | Fisher and Paykel Refrigerators
Hi, I have a Bosch undercounter freezer and it won't stop beeping!!! All the lights flash whilst beeping, the lights are under the super freeze button, mute button and the temperatures. If I hold...
The beeping is a signal that the fridge has not got down to, or holding temperature... You may have a thermostat or gas system fault. Check and see that the fridge has actually got cold.
Jul 31, 2011 | 2007 Harley Davidson FLHX Street Glide
Hi I I have Audi 2..5 v6 tdi, when driving at speed of 10mph a warning beeps and a yellow sign showing mph. It beeps every time I go over 10mph and doesn't beep again until I Stop and manoever off...
Hi your car got a speed warning system in the dash you need to reset it,check on your steering wheel or wiper and inticator levers for buttons for dash menu some models have a reset button also.hope this helps.
Jul 05, 2011 | 2002 Audi A6
I have a Fisher and Paykel Active smart fridge. Every few hours it starts to beep, the fridge and freezer is still chilling but i can't work out why it keeps on beeping. I just push the plus or minus sign...
I had the same problem. The problem proved to be the defrosting element was faulty. The defrost is programmmed to activate every 12 hours or so, and if it does not happen the electronics detects any problem and sets the alarm. Replace the defrost element and everything is fine.
Oct 25, 2010 | Fisher and Paykel Refrigerators
Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Apr 01, 2009 | Refrigerators
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
455 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
