Question about Techtronic Industries, Inc. Ltd. Ryobi One+ 2 Pc Starter Kit
Need Battery Pak for Wagner Pro Gold Drill. Battery pak #0287162
Pokemon stadium said that i need pak but i have one
Verify that only licensed accessories are being used with the system. Unlicensed products are not fully compatible with Nintendo systems, and may not work correctly.
Check the game pak manual or packaging to verify that the game is designed to be used with the N64 Transfer Pak.
Make sure the Game Boy game pak works properly in a Game Boy system. It may be a problem with the Game Boy game pak and not the Transfer Pak.
Verify that the game paks are inserted in both the control deck and the N64 Transfer Pak. If they are not, insert them and then turn the control deck power off and back on again.
Verify that the controller is plugged into the proper controller socket on the front of the control deck. If it is not, secure it and then press reset on your control deck.
Remove and re-insert the N64 Transfer Pak, making sure the pak is fully inserted into the bottom of the controller. If it is not, secure it and then press reset on the control deck.
If possible, try another controller. If the Transfer Pak works in another controller, it may be the controller that is having a problem. Check out controller troubleshooting (click here).
If the issue persists, the Transfer Pak may need to be replaced. For information on locating replacements for older products, please click here.
Jan 02, 2013 | Nintendo 64 Console
I have an old N64 and to play majora's mask it says i need an expansion pak so i ordered an expansion pak but when i replaced the jumper pak with the expansion pak the system still turns on but for some...
If your Nintendo 64 console operates without error when the jumper pak is installed, but fails to function when the expansion pak is installed, by process of elimination this most likely means that the expansion pak you purchased is defective.
However, prior to purchasing another expansion pak (or attempting to exchange/get refunded for it), make sure the contact points on both the pak and the console slot are free of any dust, dirt, or other contaminants. Use a lint-free, dry cloth to do this. Water and/or cleaning products can further damage the system.
If, after cleaning the contacts, it still fails to function, seek an exchange or refund.
Mar 03, 2011 | Nintendo 64 Console
When i put my power pak in the light come and go right back of and it would'nt charge
Could be the battery is fully charged. Otherwise if the light goes on and off, then the battery may need replaced. YOu can buy them online at a reasonable price.
Sep 22, 2010 | Ryobi Multi-Volt Battery Charger
Ever since buying a "re-Chargable" battery pak for Wii Fit it takes off more weight than should be (approx 3.7KG more). The Wii Fit has been working great up until the Battery pak. Strange thing is,
If you're using the Wii Fit on carpet, you need to use the additional legs that came in the package. Simple pop 'em on and they should (hopefully) fix the problem.
May 24, 2009 | Nintendo Wii Fit for Wii
Nintendo 64 Transfer Pak...
Try cleaing the contacts on the games and the transfer pak itself, look up how to clean games on youtube.
Jan 27, 2009 | Nintendo 64 Console
Nintendo 64 Pokemon Stadium Transfer Pak Error
Its most likely the controller. When you put in the pack is it loose? You could try cleaning the GB game and trying again.
Jan 26, 2009 | Nintendo 64 Console
Kirby 64 won't hold a save file
The battery inside the game pak has died, thus, it can no longer hold a save.
Buy a special screwdriver for n64 Game Paks. Unscrew the casing, then find the battery inside the Pak. Take it (the battery) to any store that sells watches, then ask for a replacement for that battery. Plug the batery (+ side facing you) in the Pak, then screw it back together.
Your game should now save. :)
Nov 22, 2008 | Nintendo 64 Console
Controller Pak Abnormality???
Sorry evilpacman, but you're wrong.
The N64 Controller Pak does indeed have SRAM as you state, but SRAM _does_ require a battery to retain its contents. The battery in question is a standard CR2032 or "coin-cell". The only gotcha is that it is a PCB mount variety, with the legs already attached to the battery casing. I'm currently looking for a replacement myself... farnell may have them but I need to check the footprint...
Jul 13, 2008 | Nintendo 64 Console
Techtronic Industries, Inc. Ltd. Ryobi One+ 2 Pc Starter Kit Logo
425 people viewed this question
Top Techtronic Home Fencing Experts
 Russ Hill
Russ Hill
Tom Chichester
ray gallant
Are you a Techtronic Home Fencing Expert? Answer questions, earn points and help others
