Question about Jl Audio Stealthbox Single 10" VW Passat 98-05 Speckled Gray
Wire a tow bar to a passat - Jl Audio Stealthbox Single 10" VW Passat 98-05 Speckled Gray
    Problem Solver:
  • 11 Answers
I see the UK after your name. If it means across the Atlantic, this solution mught not be appropriate, but if these colors are present in your wiring harness, then what I say is correct. By electrical towing standards. white from the tow is ground which is any clean spot to connect to on the frame of the vehicle. Brown is connectted to the tail, parking, or running lights which is one of the 2 wires that connect to the Two-filiment bulb in the rear reds lights of the vehicle. The green and yellow are the trun signals (left yellow & green right) or (left green & yellow right) which are connected to the other wire in the pair to the two-filiment bulb. These two colors are combined when you push the brake pedal to show stopping lights. So if you don't have break lights you probably don't have turn signals. There are no back up lights in a tow situation. Do not cut your vehiicle wires. Use crimping connectors that crunch on to your existing wires with another wire. Have extra fuses for myyour vehicle.
Posted on May 12, 2010
Good morning , on the dash , the warning lights are coming on , saying lh indicator faulty , rh brake light faulty lh sidelamp faulty , but we have checked all the bulbs and they are all fine ...any i
Do you have a tow bar fitted? Sounds like a wiring problem earth short usually a badly wired in tow bar can cause it as they wire them into the light cluster using scotch locks they need soldering properly. Failing that or no tow bar fitted have you got water ingress in the lights Definately sounds like the rears
Nov 25, 2014 | Cars & Trucks
Wiring diagram tow bar suzuki grand vitara sz5
we dont know what you are doing
are you :
  1. adding one.
  2. removing one.
  3. or diagnosing one.
I guess you have and RV and are planning to tow a suzuki?
try to say what';s UP first then ask.
May 25, 2014 | 2010 Suzuki Grand Vitara
Need directions to fit towbar and wiring on holden captiva sx (2007)
there is a standard tow bar and a 2000kg for genuine tow bars
you need to remove both tail lights,the bumper bar and reinforcement bracket, spare wheel and exhaust hangars on rear mufflers, remove the tie down bracket on LHS chassis rail(dont need this or the bolts that hold it on), so you can then bolt in place either of the 2 tow bars.
genuine wiring patch harness for trailer plug is my suggestion since its plug straight into vehicle and interfaces with vehicle, goes in right hand rear compartment remove lid then remove box, interface connector for trailer harness is there.
instructions can be printed out from dealers if you ask
some new kits dont come with instructions in kits because information is on dealer computers
there is a template to print out to cut hole in bumper bar for tounge area of tow bar, uses centre square dimple in bar but its a bit wider.
Sep 05, 2011 | Daewoo Korando Cars & Trucks
How do i wire up a tow bar electrics ?
Obtain a tow wire harness. Then tap into the existing wires on your vehicle, if it is not prewired for towing. If it is prewired, you will notice a bundle of wires near the rear of your vehicle. Attach these to your tow wire harness and then to your tow hitch.
Oct 02, 2010 | Ford Focus Cars & Trucks
Where do i feed the wires through to wire up the towbar on a 1997 honda crv?
If you have a wired tow hitch on your car you will need to mate this to the wiring harness on the tow bar. If the two wired units do not match then you will either need an adapter or will need to rewire the tow dolly or the car. If the car doesn't have a tow light unit installed you will need to install one that will mate to the tow bar light unit.
I hope this helps - please rate me
Mar 18, 2010 | 1997 Honda CR-V
Diagram for 03 reg passat towbar wiring
Hi Katrina.
The most common wiring for a 7 pin tow-bar plug is as follows.
E.U.Standard
No 1 Yellow-----Left side flasher
No 2 Blue ---- Fog Lights. (Often un-used)
No 3 White --- Earth
No 4 Green -- Right side flasher
No 5 Brown -- Left side park light
No 6 Red ----- Brake lights
No 7 Black--- Right side park light.
The numbers can be found on the rear of the socket.
However---wiring may differ from Europe to the US.
All the best
John
Aug 31, 2009 | 2003 Volkswagen Passat
VW Passat transmission
I got same problem now. Did you find a Solution or figure out why transmission will not engage after being towed. Same engine works great just won't shift in to gear and go.
Thanks john
Jul 09, 2008 | 2001 Volkswagen Passat
Wiring for tow bar
Can any one provide advice on wiring up a towbar electrics for my s type jaguar
Jun 27, 2008 | 2003 Jaguar X-Type
Jl Audio Stealthbox Single 10" VW Passat  98-05 Speckled Gray Logo
136 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Jamie Henning
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
