Question about Canon PowerShot A70 Digital Camera
NOT TRANSFERRING IMAGES TO MY HP LAPTOP
I HAVE NOT USED MY CANON A70 FOR A FEW MONTH.
I CONNECTED CAMERA VIA ITS LEAD TO THE LAPTOP,, IT DOES NOT AUTOMATICALLY PROVIDE ME WITH SEVERAL CHOICES AS TO WHAT I WISH TO DO. IF I CLICK ON THE A70 IMAGE IN MY COMPUTER IT ASKS ME TO CHOOSE FROM THE MENUFIELD PROVIDED AN OPTIAN - HOWEVER - THE FIELD IS EMPTY AND NO OPTION IS GIVEN
WHAT TO DO .. PLS ANSWER ASAP TXS FOR THAT VERONIKA
Ohh maskina .. Bring to me here in Oman i will Fix it :P
Posted on Aug 26, 2008
Hi i have a a70 bought a few yers ago its been working fine but now it doesnt tranfer images to camera i e take photo but nothing on flash card can you suggest problem cheers jools
Posted on Jul 22, 2008
SOURCE:
EOS utility not tranfering all images on card
You are better off to simply remove the card and either use your built in card reader or obtain a external USB card reader and transfer your images that way. All you have to do is open 2 "My Computer" windows. Simply drag your photos from your card to your C: drive.
Dec 06, 2012 | Canon EOS 40D Digital SLR Camera Digital...
Power Shot A70 will snap pictures but there are no images in the monitor and replaying mode shows only red light image taken. I am still able to view past images taken but can no longer see or take...
This sounds like it might be a defective CCD imager, and is a known defect for your particular model camera.. If so, Canon should fix this for you for free if you live in the US, Canada, and a select few other countries. If you live outside the US, contact Canon support for your country to see if they'll still honor the advisory (some still will, especially if you stress you knowledge that this is a known defect of the camera). They may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please see this link for more info.
Feb 07, 2011 | Canon PowerShot A70 Digital Camera
Does the A70 need a memory card in order for it to take pics?
Yes. The camera has a very limited internal memory only used to buffer (temporary storage while processing) digital images. You need a CF Card (type 1) to save and store your images.
Feb 05, 2010 | Canon PowerShot A70 Digital Camera
Computer will not recognize canon A70 Camera
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Sep 02, 2009 | Canon PowerShot A70 Digital Camera
Transferring images to computer
Nov 29, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
TRANSFERRING VIDEO FOOTAGE TO COMPUTER
you can access via USB only SD card on your camcoder.
The only way to transfer from the tape is via Firewire (IEE 1394) . You should have this port on your PC or laptop, if not you can buy external firewire card .
regards,
Konstantin
Aug 06, 2008 | Canon MV530i Mini DV Digital Camcorder
Memory card error
Dear jk_cibergirl:
It is likely that some type of corruption has happened to your memory card. Try reformatting the card in your camera to correct any problems. If that works then you should be fine to take more pictures from this point. If not, you may need to get another memory card. Check your memory card manufacturer for warranty information.
Just a few tips to help you avoid this problem in the future:
1. Even though your computer can format a memory card, do
not ever do so from your PC. Your computer lays down a
different type of file table than your camera, which can lead
to data corruption.
2. Always format the memory card in the camera it will be
used in after each downloading session AND even when
using a brand new card right out of the box for the first time.
3. Do not share cards among cameras - even if they use the
same type of card - even if they are the same camera model!
Consider your memory card to be camera specific.
4. Do not place your camera close to strong magnetic fields
(e.g on top of a television)
5. Lastly, even though your camera has a single image erase
button, do not do what some do and fill your card up and then
go into the playback mode and erase a few images just to
take a few more new images. This almost certainly will lead
to data corruption on your card. Download your images and
reformat the card to take additional shots.
If you need to recover any lost images from that memory card, you can give it a try by simply downloading free software from the internet (such as Zero Assumption software available at www.z-a-recovery.com), connecting your memory card to your computer via a card reader, and running the program on the card reader volume.
Hope this helps.
Sincerely,
HeavyDLB
May 28, 2008 | Canon PowerShot A520 Digital Camera
CAMERA NOT DOWNLOADING PICTURES TO COMPUTER
Suspect you have a PC/Laptop SOFTWARE problem, there. I've had this myself. Can you try and load the software on another PC, and see if that works? - Larry
Feb 13, 2008 | Canon PowerShot A70 Digital Camera
Problems when connecting Canon Powershot A70 - Cannot find program to upload pix
The popup would be the windows wizard wanting to assist with downloading image files. There's 2 popups one is the wizard and you'll click on transfer images & it walks you step by step to download the images. The other one is just a one click option & you can copy the images files to your computer. But since those options don't seem to work for you - one solution would be to click on "my computer" and you'll either find your camera or memory card listed along side your computers C drive. If you're downloading images from the camera - it needs to be hooked up via the cable + the camera probably needs to be turned on. Some cameras also have a setting or button to turn in order to download the images.
May 09, 2007 | Canon PowerShot A70 Digital Camera
Won't turn on
Ouch! You can't use an AC adapter with any battery-operated equipment you choose to just because the plug fits physically. The A70 requires 5-6 volts, and a Pavilion adapter typically puts out 18 volts. You most probably blew out your Canon's power supply within a few seconds, unless it's fused somehow. Next stop: tech support/repair shop/camera cemetery. Sorry.
Aug 23, 2006 | Canon PowerShot A70 Digital Camera
Canon PowerShot A70 Digital Camera Logo
37 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
