Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Have a murray lawn mower model 46904x192a wont stay running unless the choak is pull out'
Drain fuel in tank and put in fresh gas. Add a few ounces of Seafoam to the gas and let it run with as little choke as it will allow. The carb will clean itself. Sounds like varnish build up - stored over winter with old gas in the tank and no stabilizer.
Posted on May 17, 2010
  • 3 Answers
Have your carb cleaned by a profesional, ethanol gas is bad
Posted on May 12, 2010
Will an older 42 inch murray riding lawn mower deck interchange with an older rally riding lawn mower deck ?
Mower decks are very specific to the tractor. Unless it was the same manufactured mower, and just branded differently, then not likely! Belts are your next problem as even an inch longer or shorter will cause problems.
May 07, 2016 | Murray Garden
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
I have a problem with the safety switches on my riding lawn mower
e841a1bd-a315-49bb-ae7c-9ba2aedccbb6.gifCheck this diagram. It is most likely the deck switch. as this is a safety switch i would recommend replacing it instead of bypassing it.
Jan 13, 2014 | Murray Garden
Murray wont stay running when hot
How long will it run after it stalls and you restart it? Or can't you restart it until it cools
Aug 31, 2013 | Garden
I'm tring to put a drive belt on a murray lawn mower.
Here is a link to a website I like to use for diagrams and user manuals for mowers. You'll need the model number, obtainable from your mower:
http://www.outdoordistributors.com/Murray/Murray_Main.html
Hope this helps... Good luck!
Oct 09, 2009 | Oregon Scientific Oregon Fusion Blade For...
I have a murray centina 4.5 lawn mower and my
keep washing out the tank with water ? then try a can of starting fluid use it too keep it running until all the contamination is out of it ? if it still wont run the you must r&r carb and rebuild it also check for rust in tank?
Aug 26, 2009 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
336 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
