Question about HP 1040 Plain Paper Inkjet Fax
I have an HP 1040 fax machine. The machine is not printing, even when I do a Self Test. It goes through all the motions of printing, but nothing shows on the paper at all. The ink level indicator says 5/8. What should I do?
    President:
  • 1,561 Answers
First, power off the printer and power on back after a while, if it is not still printing, I suggest you check the ink level on the printer cartridge, it is possible that the ink in the cartridge is below printing level, that is why it is not printing anything on the paper, if the ink is below printing level, change the ink cartridge and try to print, if it did not still print, it means you will have to uninstall the printer driver from your system and reinstall back.
The two mentioned solution should solve the problem.
Take care.
Posted on May 12, 2010
  • johnabuck May 13, 2010
    Your reply says to look at the ink level, but I already mentioned in my original note that the ink level indicator says 5/8. So, why would the ink be out as you say? Is there anything that would cause the ink not to flow?
  • Sulaimon Jimoh Olayemi May 13, 2010
    One of the problem that could make ink not to flow from cartridge is when the driver of the printer is corrupt, as i said earlier, uninstall the printer driver and install back after uninstalling. this can help solve the problem of printer not printing.
    Secondly, you can also remove the printer ink cartridge and shake very well, because it is possible that the ink inside the cartridge might be sticky, if it as been long that you have used it. while doing this, find out if the ink level inside the cartridge is still very much okay to print, if not change the cartridge with sufficient ink.
    Also, after you remove the ink cartridge, clean the surface of the cartridge, because there might be dust, smudges, and ink deposit at the surface of the ink cartridge. clean all the exterior of the ink cartridge with a soft cloth, moistened with water.
    To clean the cartridge automatically, click start or click all programs, click Hewlett-packard, and then click printer assistant.
    Click utilities, click view ink level, If the cartridge in low on ink, discontinue these steps, replace the cartridge, then try printing again.
    If the cartridge contain a sufficient amount of ink, continue to the next step. click printer maintenance, click clean cartridges. follow the on-screen instructions to complete the cartridge cleaning.
    All this should solve the problem.
    Take care.
My hp 1040 fax will not print after replacing ink? yes i removed the tape
Replace right away your fax machine and your telecom line subscription! Time to switch to a cloud-based fax service: no ink, no paper, no cartridge. The internet fax service is always on, always ready - 24 hours a day, 365 days a year.
Jul 25, 2013 | HP New 1040 Inkjet Fax Machine W built in...
Fax machine not copying?
If you have an HP 1040 or 1050 fax machine be sure tot checkout this article about the recall HP did on this machine due to a potential fire hazard. You need to contact HP before you have problems with the unit.
http://www.ccl-la.com/blog/index.php/recall-on-hp-1040-and-1050-fax-machines/
BuddyMc
Mar 01, 2012 | HP 1040 Plain Paper Inkjet Fax
My HP 1040 fax will not print after replacing ink? Yes I removed the tape.
Just wanted to let you know that machines was recalled by HP due to a potential fire hazard. Check out the details here before you have major problems.
BuddyMc
Feb 29, 2012 | HP 1040 Plain Paper Inkjet Fax
No print on copies or faxes
This is a clogged print head. This happens if the printer has been off for a long time or if the cartridge was removed and the unit left empty for any time.
Take out the cartridge and press the print part on a piece of paper. Any black lines? If not, you will need a new cartridge. Wiping the print head gently with a Q-tip moistened with PURE alcohol (99%) may restore printing.
Mar 31, 2010 | HP 1040 Plain Paper Inkjet Fax
My fax won't print, neither faxes nor copies. The paper goes through & it makes sounds like it is printing but nothing on the paper. The machine says the ink level is 6/8. I "aligned" and...
Though the ink level it said was "6 / 8", when I removed the cartridge to examine it looked bone dry empty to me. I replaced the ink cartridge. It works fine, and reports the ink level as "8 / 8".
Sep 09, 2009 | HP 1040 Plain Paper Inkjet Fax
Hp 1040 ran out of paper/after restocking now prints blank pages
Even though the toner was shown at 1/2, I had the fax machine operator install a new cartridge. Problem solved!
Aug 24, 2009 | HP Office Equipment & Supplies
Not Printing?
Buy a GENUINE HP ink cartridge. I think your cartridge is dried up.
Dec 19, 2008 | HP 1040 Plain Paper Inkjet Fax
Installed a brand new cartridge in hp 1040 fax but prints very poorly(light )
remove the new cartridge
TAKE A MICROFIBER CLOTH MOISTENED WITH RUBBING ALCOHOL AND WIPE THE PRINT HEAD ( THE PART OF THE CARTRIDGE THAT CONTACTS PAPER)
REINSTALL THE CARTRIDGE THEN TEST
ALSO YOU MAY WANT TO WIPE OFF THE CONTACTS ON THE BACK OF THE INK CARTRIDE WITH THE MICROFIBER CLOTH MAKING SURE THERE ARE NO FINGERPRINTS ON THE CONTACTS
Dec 03, 2007 | HP 1040 Plain Paper Inkjet Fax
HP 1040 Plain Paper Inkjet Fax Logo
106 people viewed this question
Seeker5211
Seeker5211
