Question about Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television
Has 2 issues. it takes a while to turn on and every once in a while you will have green lines running up and down the screen. if you wiggle the tv a little the lines go away.
  • 46 Answers
As far as it taking a while to turn on that can be your lamp getting close to the end of its life span.Or it can be the ballast starting to malfunction-As far as those green lines those sound like your light engine
Posted on May 12, 2010
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
I have a 2 year old LG LCD TV (model 42LG60) and I am having problems with the screen. I turn it on and everything is fine for a few minutes and then the screen goes to red or green lines that are fuzzy....
Not really a solution, sorry, but I've got the very same problem. I haven't noticed the time before tv faults, but nontheless, it greenscreens or like in your case, redscreens as well. I've been told to open the back, which I did to check the status of the capicitors, which I've done. But, the capacitors "seem" fine. No bulging or popped tops. So, I'm at a stand still...not sure what to do at this point. If someone gives you solution, I sure would appreciate your forwarding it on to me. Thanks. Robert
Oct 23, 2011 | LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
What is up with my 360 when ever i play it for about 30min it shows green fuzzy lines down the screen of my tv and purple fuzzy lines down my tv screen and after those two happen sometimes it will have red...
well definitely video issues of some sort. if you have a second video cable (or hdmi cable if your unit supports that) give that a try.
*assuming that doesn't work Unfortunately it sounds more likely that it's an issue with the video card inside the xbox. this may be repairable by a professional.
if you have it under warranty i would contact microsoft for a replacement/repair https://myservice.xbox.com/en-US/Pages/Welcome.aspx or call Toll free: (800) 4MY-XBOX
~best of luck!
Mar 13, 2011 | Microsoft Xbox 360 Console
Mitsubishi rearTV has intermittent wavy lines running throughout
Do you have anything to test it in 1080i? Does it do it on all connections or just one? I had a similar problem with my TV that turned out to be a bad input board. Mine would only display 1080i through the Component connections. All others would show pink and green wavy lines. It cost me around 500 to fix it. Unplug the TV. Remove the back cover for the TV. Using a NON-metal object, or gloves, wiggle the input board (that has all the video connections on it) slowly back and forth and see if the problem comes and goes. You will have to have someone watching for you. If something is loose on that board, the problem should show itself. Narrowing down the problem will probably save you money on repair bills.
May 13, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Green line down the middle of the screen
Often times this issue is caused by either a loose or damaged VGA cable. You can verify the issue often times by firmly wiggling the cable and watching to see if the line disappears. If that does not resolve the issue you will need to replace the monitor
Apr 23, 2009 | Computers & Internet
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
Green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Jul 23, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Green vertical lines on panasonic viera screen
I have two vertical very thin green lines on TV how do I fix
Jun 26, 2008 | Televison & Video
SONY KP-46WT520
does the led blink when it shuts down if so how many times does it blink? And the green line is that running up and down the screen or across the screen?
Apr 26, 2008 | Televison & Video
Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television Logo
108 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
