Question about ViewSonic VP930b 19" LCD Monitor
Montior switches of when i turn it to the side
Monitorswitches of when i turn it to the side
  • 31 Answers
I m sure its somthing wrong with ur monitor cable(wire) try to claim warranty or giv to a monitor repair center to fix a new cable
Posted on May 13, 2010
Testimonial: "Yeah"
My onkyo receiver wont play music loud, I can turn it all the way up and faintly hear some music, how can I fix this? The speakers are hooked up, but there is no sound, the receiver model is txsv373...
The most common cause of this is having the unit with the tape monitorswitch turned on. Check that first. If that is not the problem, the next likely problem is in the power supply. The output section is missing its main voltage. This will require professional assistance.
Please try the tape monitor first and update this with the results.
Dan
Aug 25, 2010 | Onkyo TX-DS555 Receiver
I have 2 Soyo DYLM246d Montiors when i plug them in nothing happens wont turn on nothing at all. Is there a Fix or are they junk?
Check your power cable and try to replace the cable and clean any dust on the LCD and try to switch on and check the power unit also
Aug 17, 2010 | Soyo DYLM24D6 LCD Monitor
On the right hand side of montior the is a screen
There might be a tool on your computer about that, you can check the utilities programs on your computer by searching in the Program groups of your Start menu and disable it. Your manual may give you some idea how to disable it. If you right click on that pop up window you might see an option to stop it from popping up. If those are not working, press CTL+ALT+DEL and select the task manager, then kill the process with a similar name. But you don't want to kill too much otherwise other applications may be affected too. Hope that helps.
Jul 09, 2010 | E-Machines eMachines Desktop PC
Monitor switches on. shows screen for about 5
Make sure your computer is working properly. Hook up another known working monitor up to the computer and turn it on. If you get video on the known good monitor then that means the original monitor is bad. If you don't get video on the know good working monitor then that means the computer has no video output and the computer would need to be troubleshooted.
Nov 30, 2009 | HP Compaq FP5315 15" LCD Monitor
How to disable the resolution notice on VG930m
Use your monitor buttons to look for Resolution Notice and turn it off.
To disable the notice on ViewSonic 23" LCD Monitor , use the buttons on the
front of the montior to do the following:
* Press #1 button
* Use down arrow to highlight Setup Menu and press #2 button
* Use down arrow to highlight Resolution notice and press #2 button
* Select Disable and exit!!
To disable the notice on NEC LCD 1765 monitor
* Press button #5 on the monitor
* Scroll up and down the menu list with Montior Button #4 and then select
with Monitor Button #5. Go to "Advanced menu" set the Resolution notice to
OFF.
Nov 02, 2009 | ViewSonic Computers & Internet
External montior is blank
Are you sure the laptop is powering up?
Do you hear the laptop boot up and the hard drive spinning and the power LED is on when you connected the external monitor?
The monitor must be powered up before the laptop for the video info to switch video port automatically.
If the external monitor is blank then you can't make it work, your video card is faulty and it is not possible to replace as it is built-in on the motherboard. You could replace the motherboard but this may not be a cost effective solution,
May 05, 2009 | Dell Latitude D610 Laptop Computer -...
Montior turns off when hooked up to tower.
Remove the video card and try to put it back in. Make sure that it is fully seated. If that doesnt work, then try replace your video card
Feb 18, 2009 | Systemax Venture PC Desktop
Montiors shut off
if the monitor goes into standbye when you plug it into the computer , it generally means there is NO signal coming from your video adaptor.
Plug the old monitor in , if it works, ide suspect the new monitor(s) are not working correctly.
if it doesnt work , you need to restart the computer in safe mode by repettitively tapping the f8 button as the computer starts, before it says "starting windows".
If you have a signal on your monitor in safe mode, then most likely you have a bad or corrupted video driver and it will need to be updated.
if you have no video in safe mode , you will need to remove the cover and physiclly check that all add-in card power cables and memory chips are squarly seatied in there slots. MAKE SURE YOU UNPLUG THE COMPUTER AND DISCHARGE ANY STAIC BUILDUP IN YOURSELF BY GROUNDING (TOUCHING) SOMETHING METAL BEFORE YOU TOUCH ANYTHING INSIDE THE COMPUTER.
AFTER YOU CHECK THESE THINGS AND TRECONNECT THE POWER AND TRY TO START......POST AGAIN HERE
Need help
Some laptops need you to turn on the external montior conection in the bios
Oct 28, 2008 | Toshiba Satellite A135-S2246 Notebook
Usercontrol automatically displayed when bootup
it is due to the 5V regulator ,replace that
Sep 15, 2006 | SAMTRON 55V 15" CRT Monitor
ViewSonic VP930b 19" LCD Monitor Logo
69 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
