Question about iRobot 4150 Roomba Vacuum
My irobot (Roomba)is only working for 10 mins then
My irobot is only working for 10 mins then stopping. It is only 17 months old and is used approx. once per week.
  • 3 Answers
It should take about 6 hrs to charge. I had the same problem and reset the charging circuit. 1) Charge it until the green light comes on. 2) Unplug and pull battery out. 3) hold down the power on button 15-30 seconds. 4.) Put the battery back in, plug in the charger (direct - not through the dock) and charge for 72 hrs. Then, run at Max clean until the "I'm dead" tune plays.
Posted on Aug 08, 2010
Stops
I had the same problem when I renovated my kitchen. With boxes of stuff everywhere it was impossible to use Roomba. When I tried to use it again a few months later, it would stop after only a few minutes work. I had to buy a new battery which cost in excess of $100. Its better to loan it to a friend to be used than to put it into storage.
Apr 30, 2013 | iRobot Roomba 530 Robotic Vacuum
IRobot will stop after few seconds ..
How old is the unit? It looks like the battery needs to be replaced.
Feb 24, 2008 | iRobot 4296 Robotic Vacuum
My irobot roomba is bumping into everything really fast and hard this just started happening this week
check and make sure your bumber isn't jammed with debris. you can briskly tap the bumper 10-20 times to try and free up anything that may be stuck up in there. it also wouldn't hurt to clean the four sensors underneath. if that doesn't work try and reset your machine by holding the power button down for 10 sec.
Feb 13, 2013 | Roomba iRobot Pet Series 532 Vacuum...
Took Roomba apart to clean and now the pick up brushes start and stop during cleaning. The vaccum is clean but will not constantly spin. Runs great but pick up brushes start and stop. Is there a number...
You can go to www.iRobot.com . This is the roomba website. You should be able to find replacement parts, customer support, videos or the Roomba product, and more.
When you cleaned your Roomba, did you also clean the wheel wells and outer most edges of the brush brush cartridges? There can be lint, threads, and at my house, cat hair, wrapped around the outermost edges of the brush cartridges.
I hope my suggestions help. If so, please contact Fixya and rate my solution.
Thanks and Good Luck!
Dec 02, 2010 | iRobot Roomba 530 Robotic Vacuum
My roomba 580 runs perfectly for 10 minutes then stops dead without returning to the charger and without the usual beep to notify you of an error
seems like a battery fault.
can you start it after it stops?
how old is it?
try reset and deep charge it
hope that helps
Dec 28, 2009 | iRobot Roomba 580 Bagless Vacuum
IROBOT - CLEANED USING WATER - NOW DOESNT WORK AT ALL
you probably got the switches wet ,make sure all the water is out,then take a blow dryer to dry out the electronics
Feb 13, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
Roomba discovery
Cleaned the shaft that the spinning brushes are connected to. Used an eyeglass screwdriver to remove the brush.
Jun 18, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba discovery stop working
Try spraying a compressed air can (computer cleaner) under the brush compartment (under the yellow housing). There are sensors and other wires underneath.
Feb 25, 2008 | iRobot Roomba Discovery SE Bagless Robotic...
iRobot 4150 Roomba Vacuum Logo
653 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
