Question about ASUS NVIDIA nForce Chipset A7N266-VM (A7N266-VM W/L) Motherboard
Tower change Hi, Can anyone help me?? Just changed my tower and now when boot it up a message comes up in BIOS, it says.. message comfirmation the system intruded, chassis openened or tempered before... can anyone guide me on how to fix this... thanks
  • ASUS Master
  • 19,396 Answers
1. Restart your machine
2. Enter BIOS by pressing F2
3. Scroll down to 'System Security'
4. Press Enter
5. Scroll down to Chassis Detection
6. Arrow over to 'Disabled'
7. Press Escape
8. Save changes and exit.
In some bios is in bios in the section BOOT and BOOT SETTING CONFIGURATION and disable CASE CHASSIS WARNING.
Your bios may be slightly different from the above. check inside the settings and find the case chassis warning option.
Regards
Posted on Mar 29, 2008
Operating System Not Found Message
dsflews 1 or 2 HDD ?
made any changes in BIOS ?
if 2 HDDs and you set optimal defaults in BIOS windows can change BOOTDISK. if two it's easy just change back.
http://www.pcmag.com/encyclopedia/term/38515/beep-codes
good reading.
Apr 19, 2013 | Dell Dimension XPS PC Desktop
Got an acer aspire ax3812 tower is on but screen stays blank got any ideas
Change the internal Ram sticks. This can cause a "Hold" in the BIOS boot process, thereby stopping the machine from going to the Operating System. Hope this helps.
Jan 29, 2012 | Acer Aspire Computers & Internet
PC boot problem
Hi Jimmy,
Does the PC load windows fully before restarting?
If it does load and then restart,then it may be a problem on the part of your hard drive.
Run a full scan of the PC with an updated anti-virus to rid off any viral attacks.Make sure the anti-virus is always updated for better performance.
If it does not load windows,try this:-
  • Restart the PC.
  • Before it loads the first page,press Ctrl,Alt and Del.This is a soft boot sequence.
  • The booting leads you to the Bios setup page.
  • Under file save changes and exit[though no changes made].
  • If problem not solved repeat the procedure again.
If the problem persists,you may have to reinstall the operating system again.
Hope this helps.Thanks!
Nov 05, 2011 | HP 2133-1 Mini-Note PC
My dell dimension 9200 is booting and then giving me a Floppy Diskette Seek Failure message. What is causing this to appear and not boot windows 7?
Hi. You computer seems to be booting up using the floppy disk and your floppy disk drive might not be connected properly, not working or not even there. Press F2 to run the setup utility and disable the floppy seek in the bios. It will most likely be in the "Advanced CMOS setup" area, or the 2nd screen depending on your bios. look for "Seek floppy drive at boot?" or, "Disable floppy seek at boot?" or something like that. When you find it, make sure it's not enabled for the seek. Save the change on exiting. :-)
Jun 05, 2011 | Dell Dimension 9200 PC Desktop
Trying to boot and change bios start up for compaq d530 sff
Unplug the case from the power, open the cover and try to locate on the motherboard a small round battery (a little bigger that the one at the electronic watches) TAKE CARE THAT THE TOWER IS UNPLUGGED FROM THE MAINS. Very carefully remove the batery and wait 1-2 minutes. After that insert the battery back, close the case, plug the tower and start the pc. It will boot at the default bios settings, without passwords but you have to make the settings again (date, boot order e.t.c.)
In case of a problem post back.
Stelios.
Feb 23, 2010 | HP Compaq d530 SFF PC Desktop
System will not boot up
Hi there
Hit F2 on boot up and go into the Bios settings, look for the boot order and change it to HDD as first boot device, hit F10 and save and exit.
The PC will restart and should boot into the hard drive.
Good luck
Jan 26, 2009 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
COMPAQ PRESARIO V-6000 LAPTOP WILL NOT TURN ON
try to start the computer and right after that press the delete key several times as it try's see if u can get into the system bios if so change everything to a default level make sure you pres the f10 to save all info and try to reboot if this doesnot work please let me know good luck
Jul 13, 2008 | Compaq Presario 5000 PC Desktop
Lg tower pc
you need to go into bios at startup, press F2 Or Delete Or Esc on bootup. When you get into the System Bios. Change the boot device priority from HDD To CD/DVD To boot first.
Save/exit And when you reboot ( with windows XP in the Drive ) you,ll get options to format or re-install.
Mike @ Compurepair.
Mar 29, 2008 | LG GMA-4082N DVD±RW Burner
Disk boot failure prompt
hi, SInce u do not have a HDD u will need to boot up from cdrom, for that in the BIOS 2nd options,change the boot up sequence first to cdrom , second to any other disk.. let me know
Dec 17, 2007 | ASUS Intel 845 Chipset P4B (P4B WOA)...
ASUS NVIDIA nForce Chipset A7N266-VM (A7N266-VM W/L) Motherboard Logo
134 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
