Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Handling and moving
Can you move the freezer on it's side without damaging it?
    President:
  • 1,218 Answers
Good day,
Should not be done. First off you should be sure it is performing properly both in temperature and cycling before accepting it.
Layed on it's side is a **** shoot. But if your stuck, drive only smooth roads slowly, and upon arrival carefully upright it and let it set 48 hours to allow the oil to return to the compressor.
If step one works out, renting a truck, if the distance is short, is best.
Posted on May 12, 2010
When i moved my kic chest freezer model kc0021-Aa, I heard an light explosive sound and now the freezer does not go on.
The following is the GE moving instructions. If you have started before the 24 hour rest period and the unit had been rotated from vertical have the compressor inspected.
FREEZER MOVING INSTRUCTIONS Please use the following steps when relocating an upright or chest freezer:
  1. Disconnect the power cord from the wall receptacle.
  2. Remove the food, defrost, and clean the freezer.
  3. Use blankets to protect the freezer finish from scratches.
  4. Place the freezer on its side for moving only if you have no other choice.
  5. When transporting a freezer, keep it in an upright position. If transporting it in an upright position is not possible, lay it down on the compressor side of the unit. Be careful to secure the door to prevent it from opening.
  6. If it has been transported on its side, set it right side up in its final location and allow the freezer to sit for the same amount of time that it was on its side (24 hrs max.). Do not plug the unit into the electrical receptacle without allowing this settling time. The unit can be damaged if it is plugged in prematurely.
If the unit was transported in an upright position there is no waiting time required.
Hope this helps?
Apr 07, 2017 | Freezers
Reversing door
some can be many can't use your head and look at the hinges
May 11, 2015 | Freezers
We sold a freezer, it was working at the time. The person got it home and plugged it in immediately and left it running for 8 hrs, before contacting us to say that it wasn't cooling. We suggested they...
if they moved it on it's side they damaged the compressor,the machine shouldn't be laid on it's side.if they let it sit for a few days it might have recovered.if it wasn't laid on it's side a wire could have been knocked off somewhere,hard to say without being there to look at it.
Apr 09, 2011 | Amana 19.7 cu. ft. / 558 liter Upright...
We are moving a old kenmore upright. Not sure of the model, but there is a "16" on the bottom of the door handle. Do we need to wait to plug it in at the new location?
Not if you move it upright, but the trick,especially on old models,
is to move it very very carefully as the motor inside is on springsm and will hit the sides of the compressor case and it is ruined.
Very Very Carefully especially on grass
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 06, 2010 | Kenmore Freezers
I moved my freezer and now will only stay cold for a short time, why?
You jard the liquids. Did you just move it a little or move like to another house because if you move a frig or freezer somewhere or lay on it's side you shouldn't plug in for an hour or more so it all settles or it won't work. Hope this helped
Apr 29, 2010 | Danby 5.5 cu. ft. / 156 liter Chest...
How to move a whirlpool freezer on its side
You can lay the freezer on its side to move. If it is on its side for over 30 Min's though you will need to stand it up for 24 hrs before you plug it back in to the power. You need to do this so the freon settles back to the compressor.
It is always best to move them standing up.
Apr 23, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Will my upright freezer be damaged if I move it a thousand miles, in a van, on its side?
Yes it probably will, its designed to sit upright because if its not the compresser could get locked when you are trying to turn it back on
Aug 31, 2009 | Freezers
Moving a freezer
Shouldn't be a problem in itself, but it's prudent to let the freezer stand the right way up for an hour or two before you turn it back on.
Nov 28, 2008 | Frigidaire 14 cu. ft. / 396 liter Upright...
Moving a Kenmore upright freezer
there would be a problem if you lay it down. it should be moved up right or max 45 degrees tilt only. oil in the compressor could go to the evaporator and clog it.
front handles could be remove only from the inside. you have to remove the plastic rack of the door and remove the insulation in order to see the bolt holding the handle.
tnx 4 using fixya,
drcool
Oct 08, 2008 | Kenmore Freezers
We recently moved it and it stopped working
check the start switch that is on the side of the compressor, it may have been jarred loose.
Jun 28, 2008 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
91 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
