Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Lost #1 and #2 speeds
I have a 2008 67 lb thrust 24 volt motorguide. Lost speeds 1 and 2 others work. Any ideas?
    Problem Solver:
  • 6 Answers
Contacts inside switch may have become corroded.
Posted on May 18, 2010
Ihave a motorguide brute hyper 67 trolling motor can't get the 24 volts to work motor runs on 12 and 24 volts and all five speeds but don't have the thrust of 24 volts
This is most often caused by a faulty 24 Volt, section, (usually damaged output semiconductors, or the drive?) in the speed controller, fault, the only "Fix" is replacement. Simply obtain the entire speed controller and replace it "En Bloc" as it were. You will need to also obtain a service manual so you can disassemble it and obtain the parts numbers for the replacement parts.Otherwise take it to a professional and ask for a "Quote" as to prospective costings and go from there.
Oct 20, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
I nned a motorguide 46 lb. thrust electric foot controlled trolling motor manual
Go to http://www.boats.net. Let me ask you a question, is it 5 speed? And if so have you lost some or all speeds but 5?. I so, them you need to take the lower unit apart and you will find solder laying in the bottom. You will see that the speed control coil wires at one if the terminals on the brush board has no solder. Clean it up along with the wires so that you see copper and re-solder. This is due to poor quality control on soldering at the manufacturer. When you re-assemble tighten the bolt 45-50 in-lbs only. No more.
Oct 02, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a Motor Guide Brute 767, 67 lb thrust 24 volt trolling motor. It will only run at about half speed even with new batteries.
I believe you may have a bad low voltage circuit board problem. I do not think they make the board any longer but you may be able to convert it to work by bypassing the circuit board. I am working on one now.
Mar 22, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
The switch keeps burning out and the motor turns about one turn and then will not turn again. Motorguide Trolling Motor Brute,767 67 lb thrust 12/24 volt Hyper Drive
i think its time to strip this motor out,, it sounds like its has a short in the field coil winding,,as its pulling far to many amps,,,,
Jul 01, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Have a 56lbs thrust motorguide that is 12/24 volt. it has three wires how do i hook it up to have 24 volt
2 of the wires are line voltage and they share a common nuetral.if they hook to batteries then the common will go to the neg of each battery and the other leads go to the positive terminal
Dec 07, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
I HAVE A MOTORGUIDE MOTOR WITH THE FOLLOWING LABEL ON IT... "EP2.3HP" WITH SERIAL #SN 42663". LABEL ON TOP OF MOTOR IS "36 VOLT DIGITAL. VARIABLE SPEED". CANT FIND ANY INFO ON THIS MOTOR ANYWHERE? IT HAS...
I need the information off the tag motor frame volts amps and shaft type and I can tell you how to make it work. you didn't leave your e-mail address, also please rate. Thank you.
Aug 08, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a great white 67 lb thrust trolling motor . I can run it at 1/2 to 3/4 power and it will run for a while but when you go to full power it will shut off and you have wait a while before it kicks back...
Sounds like it's heating up. Check your wire size. For 24 volt: 6 guage wire is reccommended - that's pretty heavy. Also check the wiring of your batteries. It's easy to get mixed up if you have 24 or 36 volt system. One more thing...check the fuse size to make sure that is correct. Hope this helps. Brian
Apr 24, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
578 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
Mike Marcotte
Mike Marcotte
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
