Question about American Standard 2860.334 Enfield Two Piece Toilet
I bought a toilet from homedepot in toronto 6 months ago. from yesterday, it keeps to refill the tank like every 10 seconds. but i can not see where the water leaks
    Scholar:
  • 102 Answers
There are a few likely causes for a toilet to leak and refill. The most common is the flapper not seating properly. Usualy on an American Standard it is a disc. Either way, they are fairly easy to replace. One test I use to see if the leak is comming from the flush assembly is to put a couple drops of food coloring in the tank and wait a few minutes to see if it appears in the bowl. If so, there is a leak in the flush assembly, usualy the flapper. Hope this heps. Please vote to let me know.
Posted on May 13, 2010
How do I prevent a toilet refill tube from slipping out of the overflow pipe?
Hello there,if you check on line you'll see there is either a funny looking piece of metal that hooks to the tube and refill pipe.They also sell a circular piece to fit over fill tube with a hole in the centre to push your tube into it.First off check and see if these didn't fall off into tank.If not Canadian tire, homedepot can help with this just have makers name of toilet or model
Apr 18, 2016 | Kohler Home
I HAVE A RYOBI PRESSURE WASHER 3100 PSI WITH HONDA ENGINE PURCHASED FROM HOMEDEPOT USED IT 2 WEEKS AGO RAN PERFECT TRYED USING YESTERDAY AND I HAVE NO PRESSURE THE UNIT IS ONLY 10 MONTHS OLD ANY SUGGE
  • I have the exact same pressure washer..bought 10 months ago from Home Depot with the same problem..no pressure. Have you had any luck finding out what the issue is?
Jul 22, 2014 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
The toilet tank takes a long time to fill up
if the water keeps flowing then try replacing the flapper if it still flows then the fill tube gasket or tank to bowl gasket need to be replaced.
Mar 23, 2013 | Home
Toilet tank fills slowly
My sister has a two year old Jacuzzi toilet that worked fine until a few months ago. Then it started to take 10 minutes to shut off after each flush. I lifted the tank cover and immediately saw the problem; at least 90% of the refill water was going into the refill pipe instead of the tank. Upon examination I discovered that the plastic part that holds the flexible refill tube to the vertical refill pipe was broken. This part not only holds the refill tube in place, it also has a small orifice at the end to restrict the flow into the pipe. The part was broken in such a way as to let nearly all the water go into the refill pipe instead of the tank, hence it would run for 10 minutes after the toilet bowl was full and waste all that water. I found a small coarse thread stainless steel screw that fit into the plastic attachment piece to help plug the orifice and cut down the amount of water going to the refill pipe. Now the toilet flushes and refills in less than 2 minutes. I'm in the process of trying to find a replacement for that part but so far no luck.
Mar 29, 2012 | Jacuzzi BK37959 White Era?? Two-Piece...
I recently bought (9 months ago ) an american standard brand model CADET 3 one piece unit and recently 1 month ago , after flushing the toilet the water fills the up the water tank but there is...
theres probably debrie in flush valve, mite also try putting food dye in tank (any color) if it appears in bowl the flapper is seeping water and activating flush valve..
Nov 21, 2010 | American Standard Cadet 3 Right Height...
I have to keep refilling radaitor tank every two days
sounds like you have a coolant leak or your heads havent been done right or there maybe a crack in the head which has not been found.
Jul 06, 2010 | 2001 Chevrolet Malibu
Amercian Standard Toilet Model 2403
replace the flapper, it is the peice that lets the water into the toilet bowl from the tank. most likley that is the problem and the cheapest & easiest fix.
Mar 21, 2010 | Home
Runs for 6 seconds every 35 min. flap replaced.
Trace the leak point with some food dye. If its the closer seal it usually a $5-6 fix at your big box hardware store like homedepot. If it is the closer take the old one with you for reference.
Mar 16, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
I puchased a new Pegasus toilet about 6 months
it is filling up too much you can adjust the arm there is a screw on the side that adjusts the leval of water in the tank
Jan 22, 2010 | Pegasus Technologies Elongated 2 Piece...
Not flushing
take the lid off the tank and make sure that the chain is still conected from the flusher handle at the top of the tank to the plug at the bottom of the tank
Dec 09, 2009 | American Standard 2002.014 - Champion4...
American Standard 2860.334 Enfield Two Piece Toilet Logo
145 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
