Question about Nvidia GeForce 8800 GT 512MB Graphic Card
Motherboad peeps once and the fan is working but the monitor says no vga connected
  • 39 Answers
You may to check your ram. 1 beep is usually a sign of ram/memory failure.
try this cleaning tips:
-remove the ram, and scrub the gold part of your ram with eraser or a clean paper. then insert it back in and see if it works.
Posted on May 13, 2010
Compaq laptop prasario cq60 won't turn on yes it's plugged in yes outlet works yes I checked all electrical connections and outlets
have you tried to remove the battery and wait a couple of minutes then re-insert. make sure your battery charger is working, light flashes also indicates low power.
Mar 01, 2013 | Computers & Internet
My laptop screen got wet now it has a dul screen and a dark area
I always start with seeing if when connecting an external monitor to the Laptops VGA output is the same or different to what you see when just via the Laptops screen. Reason is so that can narrow down to JUST Laptop screen or graphics chip, maybe even OR connection at cable either end, Motherboad or Screen.
Is the Laptop turning on alright i.e. no frying, I assume it has dried out from when it got wet. localised to screen only or possibly inside of Laptop....Lights up with power, fan spins hard drive spins, right? If so try an external monitor.
Feb 20, 2013 | Proview PL913S 19" Flat Panel LCD Monitor
I have a Sony vaio PCG 5K7P, and it's not getting started...when I switch it on...only the fan works and the lights on wifi and the charger are working....no display on the screen and no processor
Laptop on, shine a flashlight at the LCD screen at various angles.
If you see a faint image the problem is the Backlight, or screen Inverter.
90 PERCENT OF THE TIME the fault can be attributed to a bad screen Inverter.
(IF the laptop uses a screen Inverter.
CCFL backlighting uses a screen Inverter.
LED backlighting may, or may Not use a screen Inverter)
No faint images?
See if the problem is the graphics chipset, or Video Cable, or inside the Display Assembly.
Graphics chipset:
Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
This is an example of a VGA Cable, and VGA connector, (port),
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for cable example.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the monitor on. If a CRT type of monitor allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down, and at the same time tap once on the F8 key. (The F8 key is the Display Toggle-Over key)
Still no display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F8 key.
No display on external monitor, suggests a problem with the graphics chipset.
Most of the time the graphics chipset itself isn't the problem.
It is due to inadequate cooling for the graphics chipset, and this causes a problem with the MOUNTING, of the graphics chipset TO motherboard. (BGA surface mount)
If this is found to be the problem I will go into more detail.
I don't believe that is your problem, but there is NO guessing here.
We are following a diagnostic flowchart.
Good graphics on the external VGA monitor, means there is a problem with the Video Cable, or inside the Display Assembly.
A) Video Cable connections can be loose.
Connection at motherboard side, or connection of small cable to screen Inverter from Video Cable, (IF it uses a screen Inverter), or connection at back of LCD screen.
A LOT of times a loose connection can cause what you are seeing.
Video Cable could be damaged. Wires inside stretched/broken.
Inside the Display Assembly:
Video Cable checks out after a continuity test, then the screen Inverter is next in the diagnosis. (IF a screen Inverter is used)
Screen Inverter proves to be good, the problem is the LCD screen.
NO screen Inverter is used, the problem is the LCD screen.
Sony drives me crazy with their model numbering system.
What is the other model number on the bottom of the laptop?
Start with a VGN?
Post back in a Comment.
Once I have a model number I can deal with, I will post back with step by step info, and additional manual information.
(Service Manual. Perhaps pictorial guides, and video/s)
Regards,
joecoolvette
[Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The I.C., or chipset for graphics, is the graphics chipset; or more properly known as the G.P.U.
Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
Jan 22, 2013 | Sony VAIO Computers & Internet
Once i connect my gt5662 to a monitor nothing is on the screen, i know the monitor is in fine condition, i realize the graphics card it came with has 2 different slots, should i buy an adapter an hook the...
Did the computer boot to a monitor before? Is this a new monitor for this computer? The GT5662 came with an ATI Radeon HD2400 PCI-e video card. There is also an onboard VGA port on the back of the computer. The VGA port should be disabled. The ATI Radeon HD2400 PCI-e video card comes with two DVI connectors. With the back of the computer facing you, you would use the one on the right. You would have to have an DVI to VGA adapter to use them unless your monitor has a DVI connector also. Hope this helps. This is what the VGA and DVI connectors look like. _498.jpgmoz-screenshot.png
Dec 13, 2010 | Gateway GT5662 Desktop PC
Installed the board, scren displays message no signal and stays black. no peeps or beeps. usb has power so do drives and signal leds
Check the cable between your monitor and computer. If this is a new install and you have added a graphics card, you will need to boot up once using the on-board VGA. Doing so will allow you to turn off the on-board VGA in the BIOS. Then you can shut down and move the monitor cable to the new graphics card and reboot.
Dec 05, 2009 | MSI G31M3-L V2 Motherboard
Starting problem
check the processor fan is working or not. check its connector. Also check if there is any beep sound.
if processor fan is ok then disconnect all the cables, data and poewer cables. plug the power connector to motherboad only and listen if there is any beep sound there.
tell me after doing this, if problem doesnt solve.
regards,
Jul 27, 2008 | Computers & Internet
No Signal
no signal mean that vga signal from cpu is not coming to it or may be this is a cable breakage relavant to signal from cpu.
2ndly, the matter of computer shuts down is out of sense because this kind of problem doent happens at this case.
check ur vga card, if it is seperately installed on motherboard.
the other thing that u can do is that;
unplug all the cables of data relavant to hdd, cd, dvd and anyothers and then switch on ur pc. hope it should work if anything is not wrong with the motherboad and ram, including vga
ragards,
Jul 26, 2008 | Acer Aspire™ T180 PC Desktop
P5k motherboard
remove the ram, do you hear beeps?
you might want to get your hands on one of these
http://cgi.ebay.com/New-8digit-PC-Motherboard-CPU-Ram-Analyzer-Test-Card_W0QQitemZ190231285206QQcmdZViewItem?IMSfp=TL0806211611r25031
if link broken click here
Reseing the bios shouldn't be a problem go ahead, or is there something I don't know? does it void the warranty? I don't think so.
Jun 23, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Can u help me?
check the video card of your system. if it is add on card , remove it and clean. if still error exist then maybe u need another VGA.
Jan 10, 2008 | Asrock 775VM800 Motherboard
Opening fan
first open your cpu cover carefully ,by opening the screws once your cpu cover is opened then carefully remove the wire of the fan connected to the motherboad then open the screws of the fan and clean it then do the same just connect your fan to the motherboad and screw it up and its over make sure that your fan is working and its over
Nov 10, 2007 | WeatherWorks CH-V18 Floor / Box Fan
Nvidia GeForce 8800 GT 512MB Graphic Card Logo
49 people viewed this question
Top Nvidia Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
