Question about Brother SX-4000 Typewriter
The ribbon will not click on so my typewriter won't work. Do you have a large diagram of the inside so I can compare the ribbon and correction tape?
  • sfrye May 12, 2010
    NEVERMIND -- I FIGURED IT OUT, AND NOW IT IS WORKING.
  • Brother Master
  • 3,594 Answers
Go to brother.com, click on support you will find a printable manual there.
DickyO
Posted on May 13, 2010
How to correctly install the correction tape in a smith corona electric typewriter SD770
you have to turn the spool with the knob untill there is tension on the tape or it won't stay in place
Nov 08, 2011 | Smith Corona Wordsmith 100 Typewriter
I put in a new wheel and new ribbon with correction tape; was working fine but all of a sudden, it won't print correctly. It prints on the very top edge of the ribbon and the letters do not print...
On the older WW's there is a large black plastic gear on the R. side of the printer they do get tooth for tooth. try wiggling it to free it up, with the power off it should move easily.
DickyO
Oct 13, 2010 | IBM Wheelwriter 6 Typewriter
Replacement of correction tape
The correction tape cartridge "piggybacks" under the ribbon cartridge. Flip your black ribbon over, line up the front dges of the two ribbons and gently press down on the correction ribbon 'till the two wing tabs at the top are attached to the slots at the top of the black ribbon. Be sure to take up any slack in the ribbons BEFORE re- installing.
GL
Jul 06, 2009 | Lexmark Wheelwriter 15 Series II...
Replaced Typewriter Ribbon & Now Correction Tape doesn't work
Is the ribbon that you installed a correctable one? It should have a yellow or orange knob to turn it. If that knob is blue, you installed a multistrike or non-correctable ribbon.
The only other thing is you have the correction tape in backwards
Jan 12, 2009 | Brother SX-4000 Typewriter
Ribbon/correction tape
Ribbons:
Correctable film - MODEL 1230 or 1030
Nylon - MODEL 1032
Multi Strike - MODEL 1031
Correction tape:
Lift-off - MODEL 3010 for use with correctable film ribbon & cover-up - MODEL 4010 for use with nylon ribbon and multi strike ribbon.
Aug 22, 2008 | Brother SX-4000 Typewriter
CORRECTION TAPE
correction tapes will not work with multistrike ribbons. You have to use a correctable ribbon. If you can find a white out tape, it will work with multistrike. What model typewroter do you have?
Aug 12, 2008 | Brother ML-100 Typewriter
Correction Tape
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
Jul 17, 2008 | Brother ML-100 Typewriter
Correct key
Jul 07, 2008 | Brother ML-100 Typewriter
Correction tape not working on this model
This T/W has 2 tapes a black ribbon and a lift off tape the L/O tape has to be a tack free type General Ribbon T355 or equivelent. It installs below the ribbon on the left and feeds to the right.
Dec 14, 2007 | Nakajima AX-150 Typewriter
Brother ML100 typewriter
Make sure that the correction tape is place in the guides one on each side small metal guides, remove ribbon to see, it should be behind ribbon guide (closes to you). Dry lift-off tape only(#3015)
Dec 05, 2006 | Brother ML-100 Typewriter
Brother SX-4000 Typewriter Logo
62 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
