Question about Hoshizaki 250lbs/day Modular Cube Ice Maker - Combined With DB200C 200lb Pushbutton Hotel/Motel Sty...
Hoshizaki DB-130H ice machine, breaker is tripped
Hoshizaki DB-130H ice machine, breaker is tripped when icemachine dispense button is pressed.
4 Suggested Answers
  • 489 Answers
SOURCE: LG Side by Side Fridge LSC27990TT
It sounds like your refrigerator went into demo mode. Try this.  Press and hold the temperature and lock button together for 5 seconds to get it out of demo mode.
Posted on Sep 30, 2008
  • 39 Answers
SOURCE: only crushed ice comes out of dispenser
your model # is incomplete but here it goes.
1.take your ice container out and run hot water thru it. you want to defrost all of the ice build up inside of it's housing.
2. make sure the long lever under the container moves up & down when you press on it.
3.w/the container removed, you will see a fork like object and next to it amn openning w/a small plastic square part inside. make sure that part moves freely up & down. that solenoid is what gives cubed ice.
let's start there first
Posted on Jul 15, 2009
projdoc
  • 2237 Answers
SOURCE: Why is my Hoshizaki ice machine evaporator frozen
if the defrost/hot cycle doesn't work, the ice won't fall and eventually freeze everything.
Posted on Dec 03, 2009
Testimonial: "Thanks, I should have indicated that this machine is water-cooled & problem does not develop until bin is full of ice; does your solution still apply?"
How to reset Hoshizaki ice maker ?
If you just want to reset it because it is making a beeping sound, there is a small white button on the control board. just press it while the power is on. If you want more than that, please supply more info.
May 25, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Won't make ice
The bin should fill up and the machine shut off in 24-36 hours from time it is turned on. If not the condenser coil may be dirty.
1.Clean the coil this should be done every year.
The bin brain may be partially restricted causing ice to melt faster.
1. clean out the drain.
The air flow to the condenser may be obstructed.
check to make sure there is nothing covering up the grill or coil.
Nov 29, 2013 | Scotsman DCE33PA1BC 15in Built-in...
Where is the alarm reset button for KM501 MWH
Look for a small button on the control board. just press it to reset.
Sep 06, 2013 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki km - 280 mah ice maker not making enough ice
A few simple things to check is the condenser for dust. Blow it out. If their is a water filter going into the unit change it. Get some ice machine cleaner and follow directions. Do these things before calling anyone out.
Aug 12, 2012 | Hoshizaki Freezer Commercial Ice Machines...
How to reset hoshizaki ice machine
small white button on control board. press once to stop beeping. Very small but it is labeled and very hard to see.
Feb 09, 2012 | Hoshizaki Freezer Commercial Ice Machines...
My Ice machine started beeping from the fuse last night and is not working
The beeping in ice machine is a code. Take off the electrical panel cover. Carefully look for and press the small reset button on the board. This will restart the machine. If it shuts off again call a service company out.
Oct 18, 2009 | Hoshizaki Freezer Commercial Ice Machines...
We have an older manitowoc icemachine model ey 040a that we can't get make ice. It has a new compressor and the water semms to be fine too
The EY0404A was manufactured in the mid to late 80's and and uses R-502 Refrigerant. Best bet would be to upgrade to a new energy efficient unit using an environmentally friendly refrigerant. The average life of that EY0404A was about six years. Hoshizaki makes the best.
Jun 04, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Sep 21, 2008 | LG LSC26905TT Side by Side Refrigerator
Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Jul 09, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Refrigerators Logo
35 people viewed this question
Top Hoshizaki Refrigerators Experts
Tom Donaldson
Level 1 Expert
J Rosado
Marat Brikov
Are you a Hoshizaki Refrigerator Expert? Answer questions, earn points and help others
