Question about Balance CM2015 15" LCD Monitor
Just recently started flashing on and off.
My monitor just recently started flashing on and off, like it has a short in the power supply, could that be the problem. Bought it in 2005.
  • 11,361 Answers
I would look for bad caps in the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 13, 2010
My 23" Apple cinema display (2002) has black screen and code flashes three short flashes. How do I find out if the monitor is dead or the power supply?
The only way to test is to use a known working power supply or known working cinema display with the parts you already have.
Dec 11, 2012 | Apple Cinema Display 23" HD Monitor
The screen of the monitor is blank. The green power light though is flashing. I can hear a faint ticking sound from within the monitor. It is as if the backlight has just failed. The monitor have been...
The flashing power button is an indication that the power supply has failed. There are parts called capacitors that filter the output power and when they short out the power supply can't start up correctly os it tried over and over, this make the power light flash each time it tries to start up. The monitor is easy to repair if you can do a little soldering. Here is a link to a repair guide that will show you how to dis-assemble the unit and what to look for and replace to get it back going again. Te guide also has videos showing the steps.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 10, 2011 | Samsung SyncMaster 920N 19" LCD Monitor
Monitor is on but stay black, blue light flashes, ...
Check out the power supply section first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 21, 2010 | Samsung SyncMaster 220WM Monitor
Flashing green led on my hanns-g HX191D
Try it on another PC fIrst.
May 15, 2010 | Hannspree HANNS.G HX191D 19" LCD Monitor
My 2232gw started flashing, as if the starter is
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 12, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor blinking on and off. I had this problem once before with this same monitor. When you went from the screensaver to the desktop it would flicker back and forth between the image and the black. After...
Please read below if you decide to DIY:
Apr 19, 2010 | Samsung 206BW Monitor
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Does not power up
Is the amber light flashing on the monitor?
If so, you should get your power supply checked.
Jun 11, 2008 | Dell Dimension 2400 PC Desktop
No Green
Check the crt board and follow the green signal path, could have a shorted transistor or a resistor out of tolerance on that line, check all the components on that line
Nov 01, 2006 | LaCie Electron 19" CRT Monitor
Balance CM2015 15" LCD Monitor Logo
147 people viewed this question
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
