Question about Craftsman 1 Hp, 4 Gal. Air Compressor
Craftsman Air compressor outlet tube assembly
I have a craftsman air compressor model 919.166442. 150 PSI 16 gallon tank. The outlet tube has split. Is this difficult to repair?
  • 1383 Answers
SOURCE: craftsman compressor will not come up to pressure
Don"t worry, even the best techs overlook a thing or two during repairs. Lets go over some basics to determine where fault is located. You will need to do some simple tests. If there are leaks the compressor may not reach set pressure. I use soapy water on all connections and on the head/headvalve while compressor is running. Make repairs as necessary. If still low pressure, while compressor is running and has reached max obtainable pressure (still low 70 - 80 lbs), carefully place finger over intake port hole (remove filter). If the compressor is pumping normally but leaking there will be ample suction at intake and cause the compressor to speed-up when intake is obstructed with finger. If you feel plenty of suction and no visible (soapy water) leaks, then the problem is probably the cylinder /ring is not correctly seating and air is leaking past cylinder. Make sure that the cylinder /piston ring is properly alighed and that the lip on the vinyl ring is up toward the head. If you do not feel suction but rather air seeming blowing out of the intake, then the problem is the headvalve plate/reed valves are leaking. The reeds must seal perfectly on their seats and not bent or have obstruction. Replace as necessary. Only one other thing to check and that is the intank check valve. Easy to check. Run compressor till you have about 70 lbs in the tank then unplug compressor. Carefully loosen the inlet hose at checkvalve and listen for air leaking out of tank. If leaking replace checkvalve. Use caution when removing head to try and save the gaskets. Good luck on your repair and email if you have other question.
Posted on Apr 22, 2009
manhandy
  • 146 Answers
SOURCE: craftsman 15 gallon air compressor 150 psi is not
leak, listen without any hose attached to it
Posted on Jun 26, 2009
woobie dog
  • 1273 Answers
SOURCE: air compressor will not switch on
Make sure that your outlet has power to it. With the compressor unplugged, open the cap on the pressure switch. Work the on/off switch and see if the contacts are engaging/disengaging. If they are carbonized, you can clean them with a fine sandpaper or emery board. Look for loose wiring and tighten all wiring connections.
Regards, --W/D--
Posted on Jul 19, 2009
  • 5603 Answers
SOURCE: My craftsman air compressor model 919 16737 1.1 hp
Probably the check valve has failed. It apparently is where the pipe goes into the tank from the compressor.
Posted on Aug 24, 2009
mxc2
  • 146 Answers
SOURCE: what is the torque specs for a cylinder head for a
The spec is 25-30 ft lbs.
Here are the specs.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/D22629/d22629.pdf
Posted on Oct 10, 2010
I have a 3 gal craftsman air compressor. Compressor runs but will not build more than 20 psi in tank reserve. Whats wrong?
if shuts down at 20 psi regulator is set wrong
it runs but only builds 20 psi, compressor is probably worn out
Oct 03, 2015 | Craftsman Air Tools & Compressors
Charge air pro model ir330e20 builds pressure to only 60 psi and will not stop running
Cbillgreene:
Your compressor is leaking air somewhere between the compressor head and the tank. With the compressor running, feel carefully around the ends of the tube that leads from the compressor head to the air tank. You will probably feel some air leaking around one end or the other. If so... remove the tube and find out which packing has failed.
Mar 09, 2013 | Craftsman Air Tools & Compressors
I have a craftsman 1.5 hp 15 gallon air compressor model number 919.167242 . for some reason it will not charge air into the tank pass 40 psi.
it sounds like you need a new ring and cylinder kit. It looks like part number d30324. Go to www.searspartsdirect.com and enter your model number into the search and you can look for yourself and get pricing.
May 01, 2012 | Air Tools & Compressors
How many gallons/pounds of air does air compressor model # 919155612 hold
Hi sugarplum10...
Normally the tanks are regulated to about 125lbs psi
Please take time to rate me
Sep 26, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
CRAFTSMAN Air compressor Model: 919167450. IT'S GOT A LEAK" SO FAR SEEMS LIKE AIR ESCAPING AT CONNECTION OF COMPRESSOR TO TANK. THE COMPRESSOR THEREFORE DOESN'T SHUT OFF COZ PRESSURE LIMIT(PSI) IS...
Manual:
http://www.managemylife.com/mmh/owner_manuals/8336/CRAFTSMAN-Air-compressor-L0809089
Schematics:
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fP0040151-00001.png
Parts ordering:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Air-compressor-Parts/Model-919167450/0247/0703000/P0040151/00001?blt=06&prst=&shdMod=
Jan 08, 2011 | Craftsman Air Tools & Compressors
Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
Feb 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
Jul 21, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Low psi while running continuously.
i am assuming this is an oil less compressor as I have never seen a crapsman compressor that is not
you need to feel around the head and see if there is air leaking anywhere usually around the tube that goes to the tank or the pressure relief valve
Apr 16, 2009 | Heating & Cooling
Craftsman 1 Hp, 4 Gal. Air Compressor Logo
392 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
