Question about Samsung Cell Phones
I am trying to install my phone to my pc via USB. My computer keeps telling me it can't find the drive to install hardware. I am now starting fromscratch. How di I get to wizzard when my computer isn't automatically popping up with the install process?
    President:
  • 1,561 Answers
If the wizard can't detect a hardware component you're trying to add, it gives you the option to manually locate the item and then continue with the installation process.
To access the Add New Hardware Wizard, click Start, Settings, Control Panel, and double-click the Add New Hardware icon. (If you don't see this icon, click View All Control Panel Options in the left pane, then locate and double-click the icon.)
The wizard instructs you to close any currently running applications that can interfere with the installation process. When you've closed all running applications, click Next. This prompts the Add New Hardware Wizard to search for new devices, which can take several minutes.
If the wizard finds one or more PnP devices, it automatically installs and configures them. When the installation and configuration process is complete, the wizard displays a list of the new devices it found. You can then either quit the wizard by selecting Yes, I Am Finished Installing Devices or install other hardware by selecting No, I Want To Install Other Devices. Make your selection and click Next. If you selected Yes, click Finish to close the wizard.
Take care.
Posted on May 12, 2010
  • mindella24 May 12, 2010
    Hello and thank you,
    Okay, I have tried to manually install the phone but it still isnt working. It says Code 10 whatever that means. I am trying to make it so I can share info between my phone and pc. It is frustrating. Any advice helps. thanks
Does not respond to my PC anymore
Hi Dan,
Perhaps you should start with reading this Problems with SimpleTech eHow It may not be of much help.
In what way doesn't it 'respond to your computer' ? Presumably you are using an MS Windows O/S, not an Apple ? You don't say. Presumably it is not showing up in Windows File Explorer/File Manager ? Again you don't say. Try using another (different) USB port(socket) on your computer. Try using the disk on another computer to tell you whether it's the disk or your PC.
Assuming it's your PC, and that hasn't worked, enter the DiskManagement utility. You should see your system disk (boot disk) and possibly the external disk as well. Right click on the SimpleDrive disk, and select 'Delete Partition' if appropriate, else go straight to 'new Partition'. I am going to tell you to reformat your disk. You will lose any data that it contains (now is a good time to remind you to ALWAYS keep BACK-UPs of your data). DO NOT REFORMAT YOUR SYSTEM DISK. Select ' New Partition' if you want to proceed with this operation, and follow the instructions, selecting the appropriate letter to assign to the disk. After about 1hr assuming USB 2, it will finish. The disk should now be visible in File Explorer.
You might also try, ensuring you have only this disk connected to your PC on the USB system (I'm assuming that is how you're connecting the disk to your computer, you don't say), entering DeviceManager, and going to USB Devices, expanding that entry. Now double click on the entry which says 'Mass Storage', and click the button which says 'Uninstall Drivers' (you may have to click the drivers tab to see this button). It will ask you if you are sure, click yes. After it has done this, disconnect the drive and reboot your computer. Now plug your drive into your PC by the USB port again; hopefully it say towards the bottom right ;new hardware found', 'installing drivers for your new hardware', and finally 'your new hardware is installed and ready to use'.
10.April.2014
Apr 10, 2014 | SimpleTech Computers & Internet
How to exchange data from my pc to my phone. my phone is a sony ericson w705
Hello and Welcome to FixYa!
You can do it via your USB Data cable, that comes with the phone.
If you have it, just plug it in your Pc and then in your phone, your phone will pop-up wit the message select "Mass Storage" your phone will restart itself in the storage mode. Then wait for a minute, you will see another driver in your "My Computer/Computer". That is the data drive open it and you will see all the folders there like Pictures,Music, Videos... Put the data from PC in those folders accordingly and unplug the hardware. Done
Another option is download and install the PC Suite from here. and select "Phone Mode" when asked by the phone, you will be connected via any medium possible. Like if it cable then cable, if Blue-tooth then so. Done.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Feb 28, 2011 | Sony Ericsson Walkman W705 Cell Phone
Connected but not detected?
Hi, You need to run updates for your computer. Go to start, program, windows update, run and install all the updates, look especially for any update for hardware, select it and let it install. Leave the My book attached to the computer while searching for updates. Good luck.
Dec 21, 2009 | Western Digital My Book Essential Edition...
My HP compaq d530 doesn't detect any USB drive. I'm trying to upload a sound driver onto it and I don't have a CD. I put the driver onto a USB drive but the computer doesn't detect the drive. I just...
So we have two problems one your sound is not working and two your usb drive is not detecting any connected devices, correct?
Starting with the sound simply use a friends computer to burn the audio driver onto a cd. Next install the driver on your machine.
Problem two the usb. Remove the flash drive and try plugging in any other usb device such as a printer or camer or cell phone and see if windows says found new hardware. You don't need to install it this will simply tell you if your usb port is functioning or has a problem. if you do get a found new hardware message then your usb port is functioning and may only have a problem seeing your flash drive. Try uninstalling the usb port in System Properties. Right click on My Computer then left click on Properties. Now click on the Hardware tab. Now click on Device manager. Now go to the bottom where the usb devices are and uninstall all usb devices and when your done restart the machine. See if you can use your flash drive now. Other wise check your bios settings for the usb devices to see that they are infact set correctly and if you cant do this take it to your local pc repair shop and they can do this for you.
Hope this helps.
Sep 24, 2009 | HP Compaq d530 CMT PC Desktop
I have a external hard drive that doesn't appear in my computer
check rectefier diodes and fuses from hard drive circuit board.
May 30, 2009 | Maxtor Hard Drive
Samsung tocco
You can't debrand your phone with Samsung PC Studio software! Try davinciteam.com.
May 20, 2009 | Samsung Cell Phones
Whentrying to installed any new hardware.PC wont work new items
MY FRIEND THERE IS PROBLEM IN UR USB PORT.PLZ CONTACT TO GOOD DEALER OR WHR U PURCHASED UR LAPTOP
Mar 28, 2009 | Acer Aspire 5101WLMi Notebook
Shadow not connecting on internet sharing..
Uninstall ActiveSync.
Reboot.
Download ActiveSync 4.5 from Microsoft.
Install ActiveSync
Do not connect the phone to the PC via USB yet.
In the phone, goto Internet Sharing, select the internet connection and select "USB", and click connect.
Afterwards, connect the USB to the PC.
Wait up to 30 seconds and vola! You have internet access.
Jul 07, 2008 | HTC Shadow Smartphone
How to install themes of motorola l7 from computer
Use Motorola phone tools software to access your phone via USB cable then upload to phones theme folder from there
Feb 10, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Cell Phones Logo
63 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
