Question about Samsung Optics
Scratched lense on 8x50, any idea where i can get (im in ireland)
Scratched lenses on 8x50 swarovoski binoculars, any idea where i can get them repaired?
    Brigadier General:
  • 3,006 Answers
The good news is that as your binoculars are a premier brand, there is extensive after-sales care and spares support so almost any fault can be repaired.
Scratched lenses can only be remedied by replacing the damaged lens; due to surface coatings on the lenses (both optical and Swarovski's exclusive non-stick coating) it's not possible to polish out the damage. Even if you could, it would alter the shape of the lens and therefore adversely affect it's optical properties.
The bad news is that a scratched lens is not covered by the manufacturer's 30 year warranty so you'll have to pay, and it won't be cheap! But it's definitely worthwhile in view of the extremely high price of the product when new.
You should click on this link to find out how to get the repairs done (or use this link if you're in the USA). Basically, the repairs are usually done by the Austrian factory except if you're in the USA .
Before having the binoculars repaired you need to consider whether the damage is functional or merely cosmetic. If it's the latter, then there's no need to have them repaired unless further damage occurs. If the damage actually affects the viewed image then it may still be acceptable if it's only infrequently evident (e.g. due to bright objects in the dark, or only when the Sun is at a particular angle).
Please take a moment to rate my answer. If my reply has not fully answered your question the please add comments instead and I shall endeavour to fully address your comments.
Posted on May 12, 2010
  • Obertelli
    Obertelli May 12, 2010
    Also meant to add a link to a copy of the manufacturer's warranty. Please click here (.pdf file)
How to clean ipad screen
best is a microfiber towel which you can buy in many shops and can also be cut in small pieces.
  • microfibers lift dust and oils from delicate surfaces without the use of chemicals
  • Ideal for eyeglass lenses, camera lenses, displays, binoculars, microscopes and other delicate surfaces
  • Non-scratching, non-linting
  • Dirt and particles are trapped within knitted tufts of the fibers
  • Ribbon-shaped fibers lift dirt and grease instead of rolling over it
clean-ipad-screen-megbyxdvyw15034h4mjt4m35-4-0.jpg clean-ipad-screen-megbyxdvyw15034h4mjt4m35-4-2.jpg clean-ipad-screen-megbyxdvyw15034h4mjt4m35-4-5.jpg
Jan 15, 2014 | Apple iPad Tablets & eReaders
Blurry binoculars
Unfortunately, the reason for the blurryness is that the binoculars will not focus. Either the lenses have become dislodged, or something is obstructing the full motion of the eyepiece lenses.
I tried to fix a pair of binoculars that had the same problem and finally gave up.
You will probably have to get them professionally repaired. Be sure to get an estimate first, though, because the repair cost may be more than the binoculars are worth, depending on how much you paid.
Wish I had better news!
Jul 14, 2011 | Optics
The eyepiece lenses have something on the inside. Can they be removed for cleaning?
  1. Carefully clean your binoculars by firstly removing any dirt or dust from the main body and straps using a soft microfibre cloth. Avoid the lenses at this point using any form of cloth on the lenses before removing all dirt and dust particles first could destroy them.
  1. Gently remove all traces of grit, dirt or dust particles from the lenses using a soft lens brush or canned air specifically designed for the purpose.
  1. Waterproof binoculars can be rinsed gently under a tap but be sure to use on lightly running water, avoid high pressure water as it could damage your binoculars.
  1. Gently remove any remaining marks using lens cleaning tools such as a lens pen or lens cleaning fluid and lens tissue. Do not be tempted to use kitchen towel or anything else lying around that is slightly rough and may scratch the surface of the lens, only use a lens pen, lens tissue or a lens cloth. Gently wipe the lens using a circular motion working from the centre of the lens to the outer edge. NEVER apply lens cleaning fluid directly onto the glass (always apply to the cloth) and always ensure that the lens cleaning fluid you are using is recommended for the type of lens coatings that have been applied to your binoculars (Do not use general household glass cleaning products or products designed to clean computer screens or glasses. Such products could destroy the lens coatings of your binoculars if used).
May 15, 2011 | Tasco 7x50 Waterproof w/Imp. Compass...
What are the differences between lenses? I know some are made of plastic and some from glass..Thanks!
There are couple of materials in which sunglassess are made of. 1. Glass Lenses
- it's has number of advantages: -Exceptional scratch resistance (don't need scratch resistant coating).
-Excellent optical clarity.
-Anti-reflective (AR) coating adheres to glass very well.Disadvantages are:-At least twice the weight of plastic or polycarbonate lenses.
-About 25 to 40 percent thicker than polycarbonate and high index plastic lenses.
-Can shatter or chip easier than lenses made of other materials.
-Require a special coating to provide 100% UV protection Second type is Plastic Lenses:Advantages:
Lightweight - About half the weight of glass lenses.
Plastic lenses accept tints easily.
More shatter - resistant than glass lenses.
Disadvantages:
About 20 to 35 percent thicker than polycarbonate or high index plastic lenses.
Require scratch-resistant coating for added durability.
Require a special coating to provide 100% UV protection.
Another type is Polycarbonate Lenses:Advantages:
Safest lens material - 10 times more impact resistant than other lenses.
Thin - About 20 to 25 percent thinner than plastic or glass lenses.
Lightweight - About 20 percent lighter than plastic lenses.
Blocks 100 percent UV rays without needing a special coating.
Disadvantages:
Requires scratch-resistant coating for durability.
Peripheral vision may be slightly less clear in strong prescription powers.
More lens reflections than glass or plastic lenses (AR coating recommended). High Index Plastic Lenses-Advantages:
Lightweight - Between plastic and polycarbonate lenses in weight.
Thin - About 15 to 30 percent thinner than plastic lenses.
Better peripheral optics than polycarbonate lenses (for prescription sunglasses).
Disadvantages:
Nov 07, 2010 | Clothing Accessories
I am trying to find out what is 6x20
Binoculars are often refered to as "N x NN" which typically refers to the magnification and the size in millimeters of the front lenses (called the "objective" lenses). 6x20 refers to 20mm front lenses (about 3/4 inch) with 6x magnification. These would be useful as opera glasses, or for spotting birds in a small backyard.
The "N x NN" designation doesn't say anything about the quality of the binoculars - just the physical size and magnification.
Oct 06, 2009 | HiStar 6x20 Sportbinox
The eyepieces lens is foggy. can it be replaced
im sure it can be cleaned. before you send it for repair why not try a qtip to clean outside lenses.. breathe on lense and softly remove moisture with a qtip...both ends..gl...larry@reichinstruments.com
Jun 24, 2009 | Cstar Optics Spy-Scope (8x20) Monocular
Cracked lense
have repaired many in the past. what lense is cracked...larry..5088331232
Apr 12, 2009 | Optics
Water spots inside lenses
On the whole, I'd advise against dismantling binoculars yourself. Unlike most other optical devices, alignement is really important because you need to feed the same image into both eyes. If you're going to end up paying someone to realign the instrument, you might as well get them to do the cleaning at the same time. A.
Apr 20, 2007 | Bushnell Powerview 13-7016 (7-15x35)...
Optics Logo
237 people viewed this question
Top Samsung Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Samsung Optic Expert? Answer questions, earn points and help others
