The LG error code OE simply means “the pump is blocked”. Presumably the
water isn’t being emptied properly. As with all error codes it is
possible that there is a cause other than the exact description in the
error code explanation but basically this error means as far as the
washing machine is concerned it thinks the water isn’t pumping out. A
pump, or filter blockage is the most common cause but it could be caused
by other faults such as a faulty pump, or even a blockage in the drain
hose or somewhere else in the system etc.Most likely pump trap is clogged up. Access it behind small door at front. Drain water out through small hose that is there otherwise water will be all over the floor when you unscrew the trap.
If the Problem Persists, it could be a Problem with Pump Motor.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
