Question about AEG B2100-4 Electric Single Oven
Oven has gone bang!!
Wonder if anyone can help? I had a problem with my oven not heating up yesterday even though the grill still heats up. Have found out that this is probably a faulty element and have since removed the element and ordered a new one. However, I tried to turn on the grill this evening with the element still out of the oven and heard a bang coming from the back of the unit causing everything to go off. No light/clock/power at all now. Could anyone please enlighten me to what the problem could be now?
  • greg_pegram May 12, 2010
    Hi, many thanks. I did not tape them up. This explains what has happened. Thank you.
    President:
  • 1,430 Answers
The wires to the element shorted out by not being connected and to close to the metal cavity. This should have tripped your circuit breaker. Before resetting reconnect the old element or put in the new one then turn on power. If nothing illuminates you will need to replace the main control. This is easy to replace but not inexpensive. You can get diagrams and illustrations at www.appliancehelponline.com All parts come with installation instructions.
Posted on May 12, 2010
Testimonial: "Cheers. That was most helpful "
  • 269 Answers
When you took the element out did you tape up the ends of the cables they may have shorted out onto the chassis of the unit.
Hope I helped
Smeg gb-ie
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jul 12, 2013 | Smeg Ovens
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Oct 27, 2011 | Ovens
Fan forced heat stop working and I open the panel cover inside to check the element size etc to replace. But element is fixed to the wall with three screws, one in the bottom of the loop and two on top on...
Aug 17, 2011 | Smeg S351X/5 Electric Single Oven
Oven was on, heard a loud bang and everything went off, changed fuse, oven clock etc came on, grill works but oven does not work?
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 19, 2011 | Ovens
Oven not working - rest of appliance fine
It is most likely that the oven heating element has failed and will need to be replaced.
This not an overly expensive part to have replaced and should be much less than the cost of buying a new oven although you would need to compare actual costs in your area.
Jan 17, 2010 | Ovens
Oven does not heat up.
You will probably find that it is the oven element that has failed.
This is to be found at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 01, 2010 | Baumatic B187 Stainless Steel Electric...
My astro x oven will not heat up, the grill still
Sounds like the heating element has gone. if you can see thee element sometimes you can see damage like a hole or melted metal with white residue
Aug 02, 2009 | Fisher and Paykel Ovens
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
May 04, 2007 | Bosch HBL 5032 Electric Single Oven
AEG B2100-4 Electric Single Oven Logo
366 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
