Question about Sony DRU-810A DVD RW Dual Layer Burner
Sony dvd try problem
My DVD RW tray is not opening
I need to open it manually
  • pavan1986 Nov 30, 2008
  • Anonymous Feb 28, 2009
    Similar problem occur, tray is not opening.
    Genius:
  • Sony Master
  • 1,550 Answers
Cambiale la banda del motor de carga se encuentra debajo de la charola del disco con ella abierta la puedes ver.Espero esto te ayude.
Posted on Mar 29, 2008
My DVD-ROM tray opens only after many tries.
As per your information you done all the basic work. Hope you use little bit of oil drop in the side of the tray. If not then try that .If no success then there is a small spring available for tray in and out function. You have to change that spring from a service center or if possible then at home.
Thanks and waiting for your reply.
Feb 04, 2010 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
DVD TRAY KEEPS ON OPENING AND CLOSING CONTINOUSLY
Hi, I have exactly the same thing. Happened before but went away when I got bored trying to fix it. This time I phoned LG support and they said take it back to Comet (they have bought out their servicing). End of conversation. Polite but firm.
Appalling support via their websites, appalling products. Never again.
Oct 05, 2009 | LG DR787T DVD Recorder
Non-opening dvd/rw
Well, it may have got jammed. so try this trick.....
If you look at the dvd/rw drive..on the side of the button of the drive...you will find a very tiny hole so take a paper pin and insert it in the tiny hole if the drive is opened great!!! otherwise get it replaced as the dvd/rw drives are not costly thesedays..
Sep 08, 2009 | Pioneer DVR-107D DVD±RW Burner
My LG multi dvd writer lightscribe tray wont open. the green light is steady. no matter how many times i try to eject the tray ang it wont open. there is dvd+r inside.
use a unfolded paperclip and insert it into a small hole below the disc tray. This is the manual eject port. Stick it straight in and push, a little bit of pressure will be needed.
Apr 20, 2009 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
Disc tray doesn't open
Unplug and plug in the powercable then try again. Be sure that the cable goes in the powerslot as far as it needs.
Good luck to you
Dec 12, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
DVD Drive will not open, has DVD stuck in it
There should be a small hole by the tray. insert a paper clip here and the drive will open manually
Dec 10, 2008 | Sony DRU-710A DVD±RW Dual Layer...
Sony DVD RW DRU-820A
did you try to do the emergency eject ?
jewellers driver in drive pinhole.
use the eject method again, Computer powered Off. Open the drawer and push it back in firmly.
This is an eject button, make/break switch problem.
Also try ejecting the drive from my computer/Right click with mouse ( CD Drive ) Eject.
And ensure the 4 Pin Molex ( Red-Black-Black-Yellow ) is the right way round. Yellow usually faces to the outside of the casing.
Mike @ compurepair.
Jul 01, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
Tray not opening
try a safety pin push it in the tiny hole just by the led light door will pop open.
Jan 06, 2008 | Lite On Lite-On SHM-165H6S DVD+R/RW -R/RW...
Disk Tray
Here is the solution. __Regards,__Arpi
Mar 22, 2007 | Sony (RDR-HX710) DVD±RW Dual Layer...
Sony DRU-810A DVD RW Dual Layer Burner Logo
262 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
