Question about Bosch WTMC852 Gas Dryer
Lights come on, but motor does not!
Dryer says it's ready, but the motor never kicks on
  • Bosch Master
  • 43,501 Answers
There can be many reasons why your dryerlights come on, but motor does not! - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 12, 2010
I have Kenmore electric dryer. When I start dryer the drum spins for couple of cycles and stops. I found out that all rollers, and pully are free to rotate but motor is too hard to turn. So I replaced
if it shuts down and then comes back on, there may be a loose wire in the connector, when the connections are weak, wires overheat, and overload protection kicks in. just an idea for you.
Dec 16, 2014 | Kenmore Elite HE4 Electric Dryer
Which wire do i test to see if my kitchenaid dryer motor is getting power
You may have to run a cycle or 'set' the dryer (dial=ready) as these wires are not continuously 'hot'. Although there are usually a white, black(or red) and ground wire. Black or red is 'hot" white is "neutral' .
I hope this helps
Jun 09, 2014 | Kenmore 63942 Dryer
Dryer won't spin...motor "kicks in" and acts like
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | GE Profile Harmony DPGT750EC Electric...
I have a 90 series dryer, it has power. lights, timer all work, but it will not start. the heater doesn't kick on and the drum will not turn.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 15, 2010 | Kenmore Dryers
When I start my dryer up if the load is to heavy the barrel won't kick up to the high speed and turn. It's like it doesn't have enough power to kick into gear, but the loads aren't that big. do you have...
The motor is going bad...
heatman101
Aug 08, 2010 | Dryers
Motor kicks out
sounds like you have a bad motor
Apr 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore dryer mod. no.110.64972301
replace the motor the start winding is staying in and the run winding is not kicking in
May 16, 2008 | Kenmore Dryers
Sears Kenmore 80 Series Electric Dryer - starts, kicks off in 5 min
sound like a motor problem it does not have a resetable limit if it was over heating then it would blow the limit and it would not heat, or the blower limit if it sences overheating would not allow the machine to run at all
get ready for a new motor, or a new dryer
200 plus to replace the motor
May 08, 2008 | Dryers
Dryer problem
you need to either clean or replace the drive motor motors have two windings start and run windings both windings kick in on start up then the centrifugal switch kicks the start windings out and the run windings take over if nothing is jamming the tub go to the motor sme times getting the lint out of the switches and motor will fix it if not replace it
Jan 18, 2008 | Dryers
Dryer won't stay on.
lots of questions spring to mind, but if you have a push button type, it will only continue to turn once the motor is in motion. centripetal action allows a motor switch to keep the dryer in operation. look in that area.if you have a belt tentioner. check for continuity.
Jul 21, 2007 | Kenmore 64952 Electric Dryer
Bosch WTMC852 Gas Dryer Logo
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
