Question about Kenmore 24032\24036 Top Load Washer
Replace "lid switch" on kenmore washer 110-20702-991
How do you take the top panel off the washing machine kenmore 110-20702-991 in order to replace the "lid switch"?
Thank you!
    President:
  • 1,430 Answers
Go to www.appliancehelponline.com/servicemanual.html this will walk you thru the lid switch replacement.
Posted on May 12, 2010
How can I order and replace the lid switch on a kenmore washer 110?
There are numerous videos on Youtube which will show you step by step how to replace the lid switch. Just type "Kenmore Lid Switch Replacement" in the Youtube search box
May 06, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitation does not stop when lid is open... Kenmore 20172 Top Load coin-op Washer needs new lid switch? Cost? Easy to Fix? Do I need a expert to do? Thank you...
sounds like the lid switch is jammed on- you can try to spray it with WD 40 or replace it it usually requires taking the machine apart to get at the wiring. Easy fis, just need patience. the switch should be able to be ordered online.
Oct 21, 2010 | Kenmore 20172 Top Load Washer
Broken lid switch on washer
you must take the cabinet off by removeing the screws from the consloe and flip it back and remove the 2 clamp,s and remove the cabinet and replace lid switch
May 02, 2010 | Kenmore 24032\24036 Top Load Washer
How to remove washer top for broken lid switch access
if it is a top loader,,,remove the screws in each end of the control panel,,,some units you have to remove the end caps to access the screws,,,then pull slightly forward on the panel and flip it back it is on hinges,,,,then remove the 2 clips that hold the back to the base,,,unplug the lid switch,,then open the lid and grab the inner lid section and pull the rear of the base towards you slightly and lift off the base,,,, then you can access the lid switch and replace it ,,,,
Apr 29, 2010 | Washing Machines
Broken switch on Kenmore washing machine
If you are referring to the lid switch, you will need to remove the exterior washer case in order to access it. This is a lot easier than it sounds. The following link explains step-by-step how to access and replace a lid switch:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions, or if you are referring to a different switch, please post back and let me know. I hope you find this information helpful.
Mar 30, 2010 | Kenmore 24032\24036 Top Load Washer
Washer does not power on and is getting power at the outlet
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I need to replace lid switch on Kenmore washer.
remove trims from edges of control panel
remove screws from under trims
rais and flip control panel over backwards(hinged at top) do not dislodge air hose to level sensor
remmove brass clips from washer body top, not position for reinstall
disconnect lid switch connector cable
lift and remove entire body
turn upsidie down
change switch
reassemble in reverse order
~20minutes
Oct 02, 2008 | Washing Machines
Don't start
It doesn't work at all If your washer doesn't seem to work at all, check these:
No power
Lid switch
Aug 10, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Top Load washer
You can replace the switch, it appears, without lifting the lid. I've ordered the repair manual (LIT4314044) but I can feel the connector and wires. It appears that the lid switch can be replaced without taking anything apart. There does appear to be a screw on the back that holds the ground in place.
Jun 23, 2008 | Kenmore 22422 Top Load Washer
Kenmore 60 series washer
Dec 07, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
948 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
