Question about Maytag PAV2300 Top Load Washer
How do I get the lid off of a Maytag Washer?
I have an old Maytag ----23+years----and I need to get the lid off
to replace the lid safety switch----how do I get the lid up? Thanks
  • 10,515 Answers
If you have broken or damaged lid hinges on your Maytag washer, the lid will have to be removed. Once you know how to take a Maytag washer lid off you can quickly replace the hinge and get your washer working again. Most Maytag washers are designed so that the control panel and the top panel can be serviced without completely removing them.
Step 1 Unplug the Maytag washer from the wall outlet. Pull it away from the wall. This will give you room to rotate the control console and the top panel into their service positions.
Step 2 Use a screwdriver to remove the securing screws that hold the control console to the top panel. Roll the control console back to allow it to rest in the service position.
Step 3 Insert a large blade putty knife between the top and front panel. Locate the retaining clips located 2 inches from each corner. Press in on the retaining clip and lift up on the top panel to release the clip. Repeat process for the opposite corner.
Step 4 Lift the front of the top panel up and rotate it back to the service position. The top panel will rest on hinges.
Step 5 Use a screwdriver to remove the hinge screw on each side. The screw is located under the top panel.
Step 6 Lift the lid hinge off of the pivot post. Grab the lid and remove it from the washer top panel.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 12, 2010
  • 2 more comments
  • lazierwhit May 12, 2010
    I DO NOT SEE THE SCREWS THAT YOU SAY RELEASE THE CONTROL PANEL----WHERE ARE
    THE SCREWS PLEASE
  • taran_2005
    taran_2005 May 12, 2010
    Thanks for your response!!
    Locate the three screws on the top rear edge of the control panel that
    secure the control panel to the rear of the washer.
    Hope i helped you.
    Thanks
    HELLO----I DO NOT SEE THE SCREWS THAT YOU ARE TALKING ABOUT. AT THE BACK OF
    THE WASHING MACHINE, THE TOP IS HELD ON WITH TWO CLIPS AT EACH BACK CORNER
    ----ONE ON THE LOWER BACK AND ONE FROM THE TOP THAT SNAP TOGETHER.
    IT LOOKS AS IF THE TOP CLIPS SLIDES THROUGH THE BACK CLIP AND A "BEND" KEEPS
    IT IN PLACE----NOW WHAT?
  • taran_2005
    Download the Complete Service Manual for your Washer :-
    http://www.servicematters.com/maytag_lib...
    It would be a Big File and would have all the Information you are looking at.
    Hope i helped you.
    Thanks
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Jul 09, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Tub wont spin, belt is o.k.
replace the lid safety switch,when it opens as in the lid is raised it breaks the circuit so it cant spin when the lid is up for safety to the operator,when they go bad it won't work even with the lid closed
Dec 26, 2010 | Maytag MAV3905AWW Dependable Clean Top...
Maytag model ka806 won,t start. Could it be a safety switch or fuse?
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.Here is the part you need.
Dec 26, 2010 | Maytag PAV2300 Top Load Washer
Maytag Atlantis washing machine SOMETIMES needs a thump to get going after filling up. this question concerns a Maytag Atlantis washing machine, about 10 years old. it has given excellent service so far...
the lid safety switch is not engaged, the hinge clips that go into the body of the washer break up allowing the lid to come out of alignment.thus the switch is not making contact. i had this same problem on my atlantis. it's an easy fix. and the clips are only about 2 bucks at an appliance parts store....
Dec 14, 2010 | Maytag Washing Machines
How to Find Lid Switch on Maytag Washer
i would recomended, becouse it is not just lid switch, on this model it is a small conroler..but if you still want it...it is on thge back of your top lid, right on the center..open your lid and look under
Aug 25, 2009 | Maytag LAT3600A Top Load Washer
Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
Aug 10, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Need to replace Lid Switch for Maytag Atlantis 2002 Washer
Hello, I can help you.
Let me explain to you how the Maytag washer lid switch works.
The lid switch is located on the controls panel, and is activated by opening and closing the washer door. The purpose of the lid switch is to prevent the washer from working with the door open.
It is a safety device to prevent the user from sticking their hands inside of the washer while the washer is agitating or spinning.
When the washer lid switch stops working, the result could be that the washer won't wash, drain, spin and in some cases the washer will not work at all.
You will need a multimeter to check the internal contacts on the washer lid switch.
You will also need to use the wiring schematic to see what contact should be close when the lid switch supposed to be on.
You will need to remember that the Maytag washer lid switch is one of the first parts that you will need to check, when the washer don't want to start filling, agitating, draining or spinning.
Jun 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My Maytag Washer
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
257 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
