Question about Miele Washing Machines
I have a miele novatronic 916 washing machine which on the start of the wash, fills up with water, then the pc check light comes on, then it drains and finishes. I have checked the filter and it was pretty clogged up, I have cleaned it out and tried again, but the problem persists. The problem is the same even if I attempt to run a cold wash cycle on it. Could anyone help?
  • paul_nova May 12, 2010
    I have a miele novatronic 916 washing machine which on the start of the wash, fills up with water, then the pc check light comes on, then it drains and finishes. I have checked the filter and it was pretty clogged up, I have cleaned it out and tried again, but the problem persists. The problem is the same even if I attempt to run a cold wash cycle on it. Can you help?
  • 11,896 Answers
You should first remove the water supply hoses and check if the water inlet screens in one end or the other of these hoses are clogged.
And if so clean the screens out and replace them back into the hoses. Then test your washer.
Posted on May 13, 2010
    Top Expert:
  • Miele Master
  • 76,846 Answers
YOU HAVE A PROBLEM WITH THE ELECTRONIC TIMER CIRCUIT, THIS NEEDS TO BE RUN THROUGH A SERIES OF DIAGNOSTIC TESTS BEFORE REPLACING PARTS BY A QUALIFIED SERVICE TECH WITH HANDS ON TESTING, THE PARTS ARE VERY EXPENSIVE SO GUESSING IS NOT A GOOD CHOICE, I COULD ADVISE U TO JUST REPLACE THE CENTRAL CONTROL BOARD BUT THAT WOULD BE AN EDUCATED GUESS BASED ON THE SYMPTOMS YOU HAVE.
Posted on May 12, 2010
    How are you so sure its the control board, couldnt it be the inlet filter or even heating element, I heard the check light goes on if the water isnt heating up?
    Thanks
    Paul
  • yadayada
    yadayada May 12, 2010
    how would it be the inlet filter stopping the wash cycle? that is not likely, nor is overheating, i gave you my expert advice based on other owners repaorted problems.
Wash motor won't run on any programme. Pumps and fills OK
Could be the motor, could be the control board could be a broken belt ...
Aug 29, 2017 | Miele Washing Machines
Miele washing machine w 487 check drain and check inlet
Clean out the pump trap. If you are on well water or just have very hard water, your inlet valve may be becoming constricted as well, remove the fill hoses from the back of the machine and shine a bright light into the valve to see if the screens are getting clogged with debris: In this case, follow the instructions the computer is giving you.
Apr 12, 2013 | Miele W487 Front Load Washer
My miele wont wash it starts up then stops an wont drain out then the water intake light comes on
Hi If appliance fills then starts to wash then stops and starts. Then most likely cause is debris in circulation motor. This will require appliance and motor to be removed
May 21, 2010 | Miele 24 in. G643Vi Plus Built-In...
Miele Novatronic W360
there is still water in the waterproof tray at the bottom of the machine and the float switch has activated. pull the machine out (if pipes allow) and tip the machine backwards to drain the water from the tray.
Jun 01, 2008 | Miele Novotronic W1918A Front Load Washer
Miele novatronic w864 washing machine
Miele novatronic w864 washing machine.This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 28, 2008 | Miele W864 Front Load Washer
Miele rinse light keeps flashing
did you check the DRAIN PUMP MOTOR ? IT COULD BE CLOGGED or something blocking the impellers
Apr 19, 2008 | Washing Machines
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Dec 20, 2007 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
74 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
