Hi my scaleoview s20-1w has gone dark for a while i could get it going by turning it on and off approx. 10-20 times but now it's gone for good could you pinpoint the problem, i suspect the backlighter circutry.
  • 11,361 Answers
Look for bad caps (bulging/leaking) first since it is easy to see.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 13, 2010
LG flip phone will not turn on. LG logo lights up screen for approx 5 seconds, then goes dark again for approx same amt of time then repeats. Tried taking out battery and putting it back.
You should try a factory reset, just google the make and model for instructions to do the factory reset, if that doesn't clear the issue you need a new phone.
Sep 28, 2016 | LG Cell Phones
Sony Brovia TV the picture went dark. You can see it but not to well.
Picture Become dark means there is some problem with the back light of the tv. can be problem with the back light led drive or the led array.
www.electro-medical.blogspot.com
Sep 06, 2015 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
My engine light came on and won't go off. Checked the oil and that seems fine. What else can it be. I am a woman in the dark when it comes to mechanics but can't afford to take it in to find out it wa
If your levels are good it can ba a faulty sensor thats triggering the light to come on.. As far as i know the gascap doent trigger the light on a accent but i'm not sure. You may have to find someone that can read out the codes and hopefully get it fixed. But aslong as the coolent and the oil are good your car should just keep running.
The light can be triggert by something like a lose cable or a sensor thats broken mostly. I recomend you try to take it in for a check up
Feb 13, 2015 | 2005 Hyundai Accent
The engine its shaking I switch one of the ignition coil because it look really burn and wasn't working now the shaking still when I start the car and while I drive in 10,20, and 30 miles it feel very...
It sounds like a coil over pack (or two) has/have gone bad. Get a diagonstic check done and that will tell you exactly what cylinder is not firing. Replace the indicated coils and you should be good.
Jan 07, 2011 | 2006 Lincoln Zephyr
Hi there I just bought a crown Victoria and the problem is the car is shaking when I drive ,I'm not sure if it's the spark plugs
you dont give me enough information?at what speed ,10,20 30 40.as you dont tell me what is happaning and when ,im going to hazard a go. tyres pressure wheel alignment,if this fails come back to me with more info.adrian,,,,,,,,,
Aug 16, 2010 | 1994 Ford Crown Victoria
Wont turn on It won't get past the start up page. It goes black
There are approx 6 reasons why this might happen:
  1. The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  2. The panel has died - Need a new panel
  3. A cable has worked itself loose or is broken
  4. The inverter has gone - Need new inverter
  5. Long shot, the bios has got corrupted - Engineer could re-flash the bios
  6. Long shot, Mainboard onboard graphics has gone - Need new mainboard
My personal opinion is that the backlight or inverter has gone - Either way it needs to be opened up to repair it, consult a service centre and get a quote or repair it yourself if your up for it.
Thanks
Sep 10, 2009 | ASUS Eee PC 900 Notebook
My acer 4520's screen is blank when i'm turning it on.
There are approx 4 reasons why this might happen:
Thanks
Sep 05, 2009 | Acer Aspire 4520-5582 Notebook
Video camera cloudy image
hi,
yes your camera needs serviceing; not much costly, approx. 20 usd.
Thanks for your question.
Jan 03, 2009 | Cameras
Samtron 15" CRT monitor gone dark but readable!
Go to a computer fair and get a flat screen monitor for around $195 dollars. Why even keep this anicent artifact in todays new screens?
Feb 28, 2008 | SAMTRON 55V 15" CRT Monitor
Westinghouse lcd w32701
This sounds like bad inverter board.
Every time LCD goes from Standby to ON state - Inverter Board resets it’s self for approx. ~1 sec, during which time you should see blue screen.
Problem is that board detects problem with voltage/current on one of the seven transformers and shuts down automatically...
As to the costs:
- BestBuy repair service approx.. $600.00
- Buy new Inverter Board & repair LCD your self approx. $200.00
- Another option is to repair Inverter Board, but parts are sometimes hard to get...
Now for the DON"T TRY THIS AT HOME or AT YOUR OWN RISK solution:
-The cheapest method is to bypass protection circuit, by transferring good signal from working transformer (using 10nF/250V capacitor) to detection circuit at the faulty transformer.
Then watch movies on your LCD unlit BAD transformer totally BURNS-OUT.
This will be obvious by dark stripe about 1"-2" tall across your display.
Hopefully the only damage will be to the transformer and not CCFL (light behind your LCD), but when you are faced with a choice of using it for a while longer or throwing your LCD to garbage right now... to me this choice was simple.
Good LUCK.
Dec 15, 2007 | Westinghouse W32701 27 in. LCD HDTV
Computers & Internet Logo
171 people viewed this question
David Payne
David Payne
