Question about Samsung DVD-R155
Problem with audio when recording
I have a R155 that I can play the TV through with vidoeo and audio but when I try and record the video is good but the audio is not there and actually stops even playing through the speakers. Can anyone help
  • 152 Answers
  • 68 Answers
There are audio two input audio ports located on R155
Rear, Composite video/audio input( RCA phono x 3 )
Front, Composite video/audio input ( RCA phono x 3 )
Check whether you are using right input ports for the recording.
Contact me again.. Thanks
Posted on Mar 29, 2008
  • Samsung Master
  • 13,433 Answers
Did it work before?
If it worked fine before its possible that some
setting has changed. So to restore default
settings follow these steps.
1st Remove the disc.
Then Press the INPUT SEL. and REC MODE buttons on the front panel of the DVD Recorder simultaneously for 5 seconds or more when the power is on. All settings will revert to the factory settings.
(Note that this function is possible only
when no disc is inserted.)
If that doesnt solve it let me know.
  • 871 Answers
have you checked the connection when you try recording? input sound is different when it comes to recording from a tv. you should have a connection check at the rear of the tv. usually this is called input and output for the tvin and out. of course when trying to just play a dvd, the source is the dvd player right so the connection at the back of the dvd player connecting to the tv is "out". when you try to record from the tv, then the tv becomes the "out and the dvd player should have connections that should be able to recieve the signal you want to record.
get my point.
    Genius:
  • 2,035 Answers
Need to know step by step instructions 0n how to record from my tv to my vcr including plug ins
I am assuming you wish to record what is playing on your TV to the VCR and not just asking how to record on a VCR, which is much easier, just put your cable from your antenna/cable box on the vcr and pick a channel from antenna or use channel 3 or 4 for cable box and press record. To watch TV with or without recording connect VCR output (Either coax or Composite) to same type input on the TV. If this is your question, then comment if you have trouble and I will get more detailed. This is a good video on doing this: https://www.youtube.com/watch?v=zgb7uoLIaQE
So if you want to record what is playing on your TV to the VCR, you must have a TV OUT on the TV. The only types of TV OUT that I have seen that would match to a VCR are either coax or RCA.
If the TV OUT is coax just connect one end of coax cable to the TV OUT on the TV and connect the other end to the Antenna/Cable IN on the VCR. Play the program on the TV and record on the VCR usually on either channel 3 or 4. Unless you have the VCR set up to play on another TV you will just have to use trial and error (record on one channel and playback on TV to see if you recorded anything, is so that is right channel, if not, then try the other one.) to find out which.
So, on to recording the signal from a TV on a VCR. If the TV OUT is Composite (RCA jacks, yellow, red, and white or black) you will need some RCA (Composite) cables. They may be labeled patch cords or dubbing cables at the store. That is if you can find them. I don't know if they are still being sold as a video accessory. If not just use RCA audio cords.
There will be two plugs on each end for mono sound recording and three for stereo sound recording. You will have to have audio or L & R audio, and video OUT on your TV and audio or L & R audio, and video IN on your VCR. Plug the yellow cable end into the video OUT on your TV and the yellow on the other end into the video IN on your VCR. Do the same for audio. I have always seen yellow as the color for video, but audio is sometimes white and sometimes black, and in stereo audio right is usually red, but left can be either white or black. With a little luck the cable plugs and TV and VCR IN & OUT jacks will match in color. If sound is mono the is nothing to get wrong. If audio is stereo the worst that can happen is the sound for right side will play on the left and sound for the left side will play on the right. As long as red is used for right it should be correct.
If there is only one set of input jacks on the VCR, the VCR input will probably need to be set to 'Line In'. If there are multiple sets of input jacks they should be labeled 'Input 1', 'Input 2', etc.. The VCR input setting will need to be set to the input you plugged the RCA cables into. The jacks you plugged cable ends into should be labeled. The setting for input on the VCR and TV should match the label on that device.
Now turn on the TV and put it on what you want to record. Do this before it comes on if you want to record all of it. Having set the VCR on 'Line In' or on the correct input, just press record on the VCR. Leave the TV on while recording.
As long as the TV is on and going to play something you want to record, you can set the timer on the VCR to record it, but instead of setting a channel you will choose either 'Line In' or the input number you are using.
This should always work to record a show on the TV when the signal is coming in through a coax cable from an antenna or cable box. But there are some TVs that only send that signal to the TV Out jacks. So if you are watching something from another source, like another VCR, a DVD player, or a video camera on TV on the TV and try to record that you will only record the incoming signal from the antenna or cable box.
In that case just connect the other VCR, the DVD or the camera to the recording VCR and play it on the one using the OUT jacks and record on the VCR using the Input jacks. This should make a better recording too. You can see what is happening by using the OUT jacks on the VCR and connecting the cable from them to the IN jacks on the TV and selecting the 'Line In' or 'Input 1, 2 etc.' matching where you plugged the cable from the VCR in on the TV.
Summary:
Device playing what you want to record is the: SOURCE
1. Using RCA dubbing cables plug them into the OUT jacks on the source and the IN jacks on the VCR.
2. Set the VCR input to the setting that matches the label on the jacks in which the RCA cables are plugged.
3. Play the program on the source and press record on the VCR to begin to record it.
Note: Leave the TV on if that is the source.
If you have any questions I assume I will get a notification if you leave a comment and I will be happy to answer.
Hope this helps. Good Luck!,
Ron
Jan 24, 2015 | Samsung Televison & Video
I can get my pictures to show on my computer but all i get with the vidoeos is sound but no picture
Hi mate,
As far as this camera is concerned, the videos are being recorded in .MOV format which is standard in these type of digital cameras. Install QuickTime player or KM Player, you can Google and get these players. They play these videos perfectly with audio and video as well.
Hope this helps. If you like it, please leave me a rating.
Cheers.
Nov 03, 2013 | Kodak EasyShare C433 Digital Camera
Problem in video recordeing from tv to camera
IT may not like that you are taking a feed from the tv to you camcorder?
IT may be detecting some form or copyright and is attempting to block the recording.
IF the end result is that you have a good recording then you should be ok. But dont take my word for it contact Panasonic corporate to see what they think.
Cheers
Al
Sep 11, 2009 | Panasonic NV-MD10000 Camcorder
Problem with Pixelview TV Tuner
I have a PixelView play tv pro3 tv tuner,2.4 hz p4 pc with 512 ram and creative 4.1(4400)speaker with cmedia audio drivers also k lite codec installed.My pc have two audio connecton. I connected audio properly but i cannot hear sound when i played recorded file.i used pixelview soft.also used windvdr also try changing the audio wires also changing settings in control panel also reinstall xp but the problem remains.please help me.
Nov 28, 2008 | Prolink PixelView PlayTVpro Video Capture
Volume loss after VCR recording
Try adjusting tracking to detent Sounds like audio heads are miss aligned . Does your unit have audio levels if so turn them up when recording. Try adjusting tracking or try patching recording unit to the tv .If it has L/R video inputs use the same deck you recorded on for playback. .
Oct 24, 2017 | Toshiba 24 24 in. TV/VCR/DVD Combo
We have just bought a samsung dvd r155, we are having great difficulty in connecting the dvd to the tv via a hdmi cable. Both the tv & the dvd have hdmi ports. When the tv is receiving the digital output...
In order to record on the DVD-R155 you need to be subscribed to Cable or Satellite and have a set-top box with the audio/video plugs and not just a coaxial cable from the wall. With just the cable from the wall you can only play DVD's. I have an older TV and need to change to channel 91 in order to play a DVD
Oct 12, 2008 | Televison & Video
Samsung DVD Recorder R155
Sounds like you recorded from a camcorder attached to AV2 (front of DVD player). Press the STOP button, then open the menu and finalize the disk.
Mar 04, 2008 | Samsung Televison & Video
Does the DVD-R155 create PC compatible DVDs?
just try to load the dvd disc.and see if it is reading..
Feb 04, 2008 | Samsung DVD-R155
"Recorded" or "Blank"? this is the Problem!
Check to see what format you are able to play on you Laptop
Sometimes they only work on some formats. Also make sure you are not recording in progressive scan
Jan 21, 2008 | Samsung DVD-R155
How to Record From a TV Using PV-GS13?
connect a lead via your tv video out audio out jacks. Select tha appropriate channel (You may have to go through the av channel on you tv and tune in the channel you want to record) or, video or dvd player audio out video out jacks. connect other end to your camcorder. Select on the camcorder menu video in audio in. Turn on tv. If connected to video or dvd player, press play. Press record on your camera. When finished recording press stop. Presuming the camcorder is tape, you can buy a tape adaptor to play or record your mini tapes in a standard video recorder, then take them out of the adaptor and play them back on your camcorder. You can also do all this via a computer. Also if the camcorder is disk or hard drive it can be used the same way as a regular dvd recorder to record tv programmes once connected to you t.v. Let me know how you go 26 red
May 08, 2007 | Panasonic PV-GS31 Mini DV Digital...
Samsung DVD-R155 Logo
114 people viewed this question
Henry  Thomas
Henry Thomas
