Question about Black & Decker D2030 Iron
D2030, Digital Iron - display lights up, but the iron does not heat, tried all settings, the words continue to flash and iron doesn't heat, normally when iron reaches desired heat setting the display will stop flashing
  • Black & Decker Master
  • 43,501 Answers
Here is a tip that will help you to troubleshoot our iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
My Black & Decker D2030 Iron fell on the floor and it is leaking water from the tank - can it be repaired?
if the crack is visible and isn't on a part that gets heated then super glue will work 4 you , plus if you cant access the crack a separate 99 cent squirt bottle kept handy will still allow you to use the iron ,just squirt and swipe the iron across the surface ,steam will be made if irons hot enough
Jun 03, 2016 | Irons
MY BLACK & DECKER D2030 DOES NOT POWER ON?
my black nd decker iron lights up but will not heat.
Jan 01, 2013 | Black & Decker D2030 Iron
Display light does not stay on when I begin to iron; The #1 acrylic flashes off and on when the light is on.
Depending on the models, most irons only have the light on when its heating up and when the thermostart switches off it cut off power and hence the light goes off.
Jan 13, 2011 | Black & Decker D2030 Iron
Iron not heating
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Iron not Heating Up or not Working Rightheatman101
Nov 10, 2010 | Black & Decker D2030 Iron
My iron heats and overheats on zero and i would have to pull out the plug in order to iron. What could be the problem?
Bad thermostat...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
heatman101
Feb 01, 2010 | Black & Decker D2030 Iron
Stopped heating
I work for Black & Decker. Any part that someone is telling you to purchase for that iron isn't from Black & Decker. Their irons are no designed to be repaired. If the iron is no longer heating, it needs to be replaced. Please call our customer service department at 800-231-9786 so that we may determine your warranty status.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 20, 2009 | Black & Decker D2030 Iron
How do I clean my Black N Decker Advantage Iron
I work for Black & Decker customer service. Our number is 800-231-9786.
You can obtain a new manual for free by visiting www.useandcaremanuals.com. Below is the section from the manual on care and cleaning of your iron.
Care and Cleaning
This product contains no user serviceable parts. Refer
service to qualified service personnel.
It is not necessary to empty the water reservoir after each
use of the iron, if you iron frequently.
To empty the iron, hold the iron over the sink with the tip
pointing down. Water will stream out of the water fill
opening.
TO CLEAN THE OUTSIDE SURFACES
• Unplug and allow iron to cool completely. Wipe the
soleplate and outer surfaces with a soft cloth
dampened in water and a mild household detergent.
Never use abrasives, heavy duty cleansers, vinegar, or
scouring pads that may scratch or discolor the iron.
• After cleaning, iron with steam over an old cloth to
remove any residue from the steam vents.
ABOUT THE SELF-CLEANING SYSTEM
• Use the self-cleaning system to flush out minerals and
lint. If lint is allowed to accumulate in the vents, it can
scorch and cause brown spotting.
For Models D2000 and D2020: Clean about once a
month.
For Models D2010, D2030 and D2035: A "CLEAN"
indicator will appear in the digital display to notify you
when your iron needs cleaning (A).
• Fill the iron as described in "How to Use" but keep the
water level below the MAX line. Plug in the iron, set
the temperature to 6, and stand the iron on its heel
rest. Allow to heat about 3 minutes.
• Unplug the iron and take it to a sink. Holding it
horizontally over a sink, move and HOLD the variable
steam dial in the CLEAN position ( ). There may be
some hissing and spitting while self-cleaning. This is
normal.
• Stay clear of HOT steam and boiling water as it comes
out of the vents while lint, scale, and minerals flush
through! Continue to hold the variable steam dial in
the CLEAN position until all the water has emptied.
If necessary, rock the iron side to side and front to back
to empty it.
• When finished, release the variable steam dial, stand
the iron on its heel rest, and plug it in. Heat for about
2 minutes to dry out any remaining water then unplug.
Please let me know if I can be of further assistance.
Jul 03, 2009 | Black & Decker D2030 Iron
F2000 iron won't heat up
heatman101
Apr 10, 2009 | Black & Decker D2030 Iron
Iron is plugged in but does not heat up. I have tried multiple outlets
check the thermostat roll switch it must be turned down to off mode select the cloth type u want to iron thten it should work.
Apr 22, 2008 | Black & Decker D2030 Iron
Cleaning a self cleaning iron
Fill the Iron with water but keep the water level below the max line. Plug in the iron and set the temp to 6 and stand iron on it's heel and allow to heat for 3 mins. Now unplug the iron and take it to a sink move and Hold the variable steam dial in the CLEAN position. There may be some hissing and spitting while cleaning so be careful. Continue to hold the dial in the clean position until all the water has emptied. If necessary rock side to side and back to front to get all the water out.When finished release the steam dial plug in the iron and heat for about 2 mins to dry out the remaining water and unplug.
May 22, 2007 | Black & Decker D2030 Iron
Black & Decker D2030 Iron Logo
1,053 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
