Question about Indesit W 123 Front Load Washer
Indesit we 14 x i want ask about code F 02 - Indesit W 123 Front Load Washer
Current year on my Hunter SRC Sprinkler is set at 02 14. Only the 14 will change.
MONTH AND DATE DUH will go t the MONTH which now is 02
Oct 05, 2017 | Garden
I have an f-02 fault code on my indesit evolution 1200 we12 wasing machine.do you know what this means? Julie
In my lists Indesit's 'F02' stands for 'motor jammed/ tacho problem, check leads' meaning that it is requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 21, 2011 | Indesit Washing Machines
F-02washer dryer problem
F02 means the motor is stuck or jammed, check the motor , tacho and module. For more Hotpoint, Creda and Indesit error codes use this link
Mar 18, 2010 | Hotpoint Aquarius WD640 Front Load...
Random disconnects
Your problem is on the Cable companies side, there is nothing you can do besides making them come out to fix it. Be warned that some ISPs are known to play the blame game and pin it all on you...I used to work for Comcast and seen this happen regularly.
In short, you are looking for a connection problem in the lines around/in your house.
The long version:
The cable wires that run around the neighborhood are the main lines. Every few houses there is what is called a "tap". The tap is a little box with a few ports to connect a regular sized cable to it(the same cable you see inside your house). Fromt he tap the cable goes to your house and "should" be connected to what is called a "ground block". A ground block should have a wire going from it to some type of ground. This is to prevent an electrical shock traveling through the lines into your house and frying anything connected to it. From the ground block it should then go into a "splitter". The splitter has 1 input port for a cable line to connect to and has anywhere from 2-10 output ports. If there are unused output ports, they should be capped off to reduce signal bleeding/loss/interference.
Okay, now the fun part. From the ground block, the next step in your line should be a 2 port splitter. So it should have a cable going into it and 2 coming out. One of the 2 coming out of it should be going "directly" to your modem. If the setup is any different than I just described, your house was wired wrong and could be the culprit to your internet problem.
There is also a possibility that your "tap" is bad, I have seen it more than a few times. A low level tech can fix this.
Also, there are boxes every so often on the main lines that run on the telephone lines. They can be misconfigured and also create internet problems. These will require a higher level technician to fix.
Next possibility is that your modem itself is bad, when you schedual a trouble shooting call with your ISP, ask them to bring an extra modem with them.
Almost forgot an important one, where the cable "screws" into any port on the tap, ground block, splitter or modem...it is not snug tight and you are not getting a full signal. This is a very very very common problem. The endings that screw into things, they are called "F-Connectors" and do periodically require to be replaced.
The tech that comes out to fix your problem, if they do not have a wave length meter on them...they do not have the proper tools to diagnose your problem. An official tech of your ISP will almost always have one on him, it is the contractors that usually do not. Ask for a real tech and not a contractor to show up.
Keep calling when you experience problems. Each time you call, ask for money to be taken off your bill for your troubles. If the person on the phone says they can not do that, ask for a supervisor.
Hope this helps.
Feb 02, 2010 | Arris SURFboard® SB5101 Cable Modem
Error l4 02 in sharp ar5132
Dear sir;the error code you ask about for sharp copier, it means drum motor problem, why don't give them a try to reset before go to replace it, the procedure is
1, press "clear", "pause", "0", "pause"key
2, press 14 then press start.
Have anymore question, please let me know,
HAVE A HAPPY HOLIDAY !!!
Dec 17, 2008 | Sharp AR-5316 Advanced Digital Imager...
F-02 fault code on indesit we16 washing machine
According to info on a similar site to this, it means motor jammed/tacho faulty or detatched
Mar 23, 2008 | Washing Machines
Error F-02
http://safemanuals.com/brand-user-guide-instructions-owner-manual/INDESIT
put in your model then download the .pdf version of your owners manual.
You will need adobe acrobat reader to view .pdf files which is a free download just go to the link below.
http://www.adobe.com/products/acrobat/readstep2.html?promoid=BONRM
Jan 22, 2008 | Indesit W 123 Front Load Washer
Showing error code f-o2 HELP!!!
f-02 should be your carbon brushes which are situated on your motor they are plastic with 1 wire going into each 1 there is 2,1 on either side of your motor
Aug 14, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
71 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
