Question about Kenmore Dryers
Heat kicks off a several minutes, and does not come back on.The ignitor does work.
    President:
  • 1,430 Answers
The problem is the dryer coils are failing. They tend to fail as they heat up.
It could also be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Posted on May 12, 2010
P3UCD12NO7601A Not Working
Check all the thermal limiters on the combustion heat exchanger. They can go bad and shut off.
Dec 16, 2013 | Sport & Outdoor - Others
Admiral Dryer Model #AGD4475TQ No Heat
This is very rare on a gas dryer but I have seen it. If you have already replaced all that other stuff I would say it has to be inside the timer. On one I worked on once I could remove that orange wire and the dryer would function ok so I ordered a new timer, they sent me a bad timer. Same problem. I finally got a working timer after going through a bunch of mess. That fixed it. So if all the other components are working it very well could be the timer.
Dec 02, 2013 | Admiral Dryers
MY carrier model #58DHC with hot surface ignitor has quit working. Blower works, but no heat. If you turn the thermostat to on fan will run but no heat. Did preliminary testings with self test on printed...
If you suspect its the ignitor? The hot surface ignitor is powered by 120v. Inspect ignitors' hot surface for cracks or burnt spots. Uplug ignitor from board. Cycle heat on and verify 120v to the ignitor at the cannon plug on the board where the ignitor plugs in. If you have the voltage then replace the ignitor. If not, you'll need to verify all other circuits are working before condemning the board. Work safe and at your own risk! Hope this helps!
Mar 25, 2017 | Heating & Cooling
Oven will not ignite; takes several minutes when it does; gas is available (can smell it)
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 06, 2011 | Wolf Range 30 in. SCB30C Gas Cooktop
Whirlpool gas dryer we have the ignitor comes on, gas lights, runs for a minute and shuts off. After about a minute the ignitor comes back on but the gas does not. thanks
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 17, 2010 | Whirlpool LGR8648L Gas Dryer
Lgq8611lw0 dryer spins but no heat
Wow that a nice gas dryer. It features electronic drying. I would make sure the sensors are clean. They get a film of dryer sheet goop on them and the sensing board cannot read dampness and shuts down the dryer thinking the cloths are dry. So check that first. Your thermostat control has 4 wires. 2 of the smaller wires warm a small heater to change the rate of time the thermosdisc opens. Newer models have a thermister. Next to it is a thermal disc.e749f09.jpg It kills power to the gas assembly but does not kill the motor. If it is open then their won't be any heat. The next thing to check for continuity is the flame sensor.db76c0c.jpg It must have continuity. It powers up the ignitor.6c68f9d.jpg If either of these are open( no continuity) then you won't have no heat. When the control is cool it powers the gas assembly. The flame sensor and ignitor kick in. The solenoids cannot kick in because the ignitor is on. When the temp gets hot enough it bends a bi-metal inside the flame sensor and opens the circuit to the ignitor. With the flame sensor and ignitor out of the circuit the surge of power can now zap those solenoids, gas comes out hitting the ignitor, and whooosh you have flames. It only take a minute or 2 of flames to warm the dryer to 160f. Then the control shuts down the operation. So what can go wrong? If the limit is blown or the control is blown then no power can get to the gas assembly. If either the flame sensor or ignitor is bad you won't get heat finally if the heat works a little bit but no more, then replace those solenoids.83a012d.jpg They tend to fail when hot and work when cold. More Here
Even more Here
This video shows how to get into your machine:
Aug 08, 2010 | Whirlpool Dryers
Tonight my master temp 250 heated the spa to 80 degrees. I went out to jump in and saw error code E05. I shut it down and killed power for a little while. Restarted system, blower kicked on, burner light...
You are right about the ignitor. Depending on how old your heater is. The ignitor can become weak and flame rectification will be intermittent. You may have to replace the ignitor assembly or at lease check to see that it's not corroded enough to impede gas flow.
Oct 28, 2009 | Pentair Mastertemp Heater
My oven heats up, but then does not maintain the temp.
If it has a pilot then I would say the thermal couple is bad. If it has a glow type ignitor then the ignitor is bad.
Sep 02, 2009 | Whirlpool GS460 Gas Kitchen Range
I have a maytag MGS 5770 ADA range/oven. The oven does not heat. The top burners and broilers work fine. However, the bottom oven burner doesnt kick in. the igniter glows red hot but the gas never...
I would start by replacing the ignitor. It could glow enough to light the oven, but to maintain the burner, it often re-ignites several times during a cooking cycle. I have had the problem before, replaced the ignitor and all was well. You should be able to find an ignitor for under $40 online. Just google 'Maytag oven ignitor' and you should find many offers. My sister just bought one for $19.99!
Mar 15, 2009 | Maytag MGS5770 Gas Kitchen Range
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
