Question about Engel Freezer 22 Qt. Fridge/Freezer
12v &240v connections on an ENGEL COOLER
If I am using the 12v supply to the unit then want to change over to 240v, do I have to disconnect the 12v supply or does the 240v take over automaticaly
    New Friend:
AUTOMATIC AC/DC CHANGEOVER: All Engel Fridge Freezers can be plugged into both AC and DC at the same time. The Engel is smart enough to use the AC while available and then automatically switch to DC when the AC is no longer working. It will also sense the resumption of AC power and automatically switch back to AC making it ideal for high hurricane areas and places where power disruption is common.
Read more: http://www.roadtrucker.com/engel/engel-12-volt-fridge-freezer-technical.html#ixzz2MvRL2xrC
Posted on Mar 08, 2013
We regularly do this, and yes, disconnect one then connect the other and it will start again on which power source you have just connected.
Posted on Jun 22, 2009
SOURCE:
We have this fridge model, engel sr65e-g3-wh, and it is making a lot of ice, the whole fridge becomes icy, 13 yr old. What can i do, do you have spareparts to repair it or can i buy a new one
You are lucky it lasted this long. Replace it. Parts are not available, and if they were, the cost to repair the unit is far more than a new Fridge.
Feb 07, 2018 | Engel Freezers
Engel refrigerator freezer not operatingg 12v
Check for power at the unit "Always disconnect power before trying to repair any appliance."
Aug 12, 2017 | Engel Freezers
What temp is the best to run my 40 litre engel for 240 piwer and solar ??
there is not BEST setting . it will be what keeps things frozen
Mar 03, 2016 | Engel Freezers
What happens when the float switch is bad?
Hello;
My name is Peter. I am a retired field service refrigeration, appliance technician.
I think you have put your question in the wrong section this section is fro freezers. Freezers do not have a float switch.
So, lets assume you have a dishwasher. There are several reasons you keep filling with water:
1.) You may have a float that is restricted with soap film. This is a white bulb on the bottom of your unit. Remove the top and clean.
2.) At the top of your float is a contact switch. This switch activates you water discharge pump. This component is about $12.00 USD.
You can check this with a Ohm meter set to the lowest Ohms. Hold the switch button in and you should get a reading of '0' Ohms.
The above is just for your information. It is not your problem.
1.) Bad Water Supply Valve - Often the water supply valve becomes worn and blocked from age. When this happens you do not get the 65 PSI water pressure to close the water supply solenoid valve. Within your control system your float signals the valve to close. In your case it does not close.
Ok, lets check out your water supply shut off valve. With a bucket under the water supply valve, turn the valve off and disconnect the hose. If water comes out, then the supply vale is plugged and does not provide enough pressure to close the water supply solenoid valve on your unit. You have a bad water supply valve.
Ok, the water shuts off. Lets look at your unit water supply solenoid valve. The spool in the valve often becomes stuck with age.
With a hair drier gently warm the valve (NOT HOT) and gently tap the valve to try and loosen the spool.
This sometimes works. In the end you are going to have to replace the valve.
This is a pretty easy repair. The valve is about $35.00 USD. If I were to make a service call at your home, I would have to charge you $350.00 USD.
Send me your model number. It is located either on the face of your dish washer after you open the door or on top of the door.
Call me and I will walk you through this @ 443-306-1362.
I will be expecting a Christmas Card in return.
Glen Burnie, MD USA
Feb 28, 2015 | Freezers
What type of a compressor that the sanyo SR - 36A uses? and can it work if remove a 110v compressor and replace it with a 240v compressor?
You can use a 220 volt compressor, just make sure the evaporator fan is also 220 volts as well as all of the bulbs, and anything else that is 120 volts. Everything must be 220 volts. including the start and run capicitors.
Good luck,
Marty
May 11, 2014 | Sanyo Counter Height, 3.6 Cubic....
Thermocouple
Does it ever actually reach the temp set? It may just need cleaning and a service so it cuts out at the right temp.
Apr 01, 2014 | Engel Freezers
Need starting ampere load and running amperes
The inverter would have to be motor rated as the starting torque is much higher than the running watts required. Starting at 240v is around 5 amps, running about 2a at most.
Mar 30, 2014 | Freezers
My camper fridge , Engel SRBT-565D Does not run on 12V ?
The compressor is on the way out and exceeds the current capacity of the 12v inverter circuit. The compressor runs on 32V AC @50 Hz and the inverter circuit is not able to produce sufficient current when the compressor becomes worn. It still runs on 240V circuit as this is a straight step down transformer from 240 volts and is not current limited..
May 20, 2012 | Freezers
Fridge does not cool down
dear sir,
if your freezer,s compressor is running the i think its low gas problem please contect to your service technician for refilling refrigarant .
hope answer the question
thank you
please vote!
Jul 01, 2010 | Engel MT45FU1 Chest Freezer
Long running periods with Engel B 12v fridge
the owners manual will tell you but yes most do
Apr 11, 2010 | Engel Freezer MT 27F-U1
Engel Freezer 22 Qt. Fridge/Freezer Logo
949 people viewed this question
Top Engel Freezers Experts
Felizardo Erilla
Felizardo Erilla
John Tripp
John Tripp
Marvin
Marvin
Are you an Engel Freezer Expert? Answer questions, earn points and help others
